Share things learned the hard way
It could break out from under you, while you're half-way up, carrying a sheet of OSB...resulting in a shattered heel, and messed-up sub-taylor joint. This would require surgery, time in a wheel chair, months in a cast, and a life of foot pain. Take it from me.
MR
Don't try to kill an engine with a hot ignition using "insulated" pliers.
Don't throw pliers at breakable objects.
Don't think that holding something with vice-grip pliers will give you more leverage than the drill you are using. One of the two will give.
Don't hold the piece you're drilling a hole in (held with the vice-grip pliers from above) too close to "the boys".
"Tough" is relative. Steel is tougher than aluminum. Both are tougher than skin.
Wire wheels, grinding wheels, and sanding disks remove stuff without discrimination. See above.
Hot metal looks just like cold metal.
Welding splatter is precision guided.
Originally Posted by fastback69
Don't try to kill an engine with a hot ignition by pulling the coil wire with your bare hands.
haha who hasn't tried that one...
Brake cleaner (or carb cleaner) shot into an orifice will end up in your eyes.
Brake cleaner sprayed anywhere in a car will run until it finds an eye or mouth to drip into. (If you happen to be under the car)
It takes at least 2 good washes to get tranny fluid out of hair.
No matter how hard you try, RTV will always end up on every finger and an elbow.
and you enjoy explaining to the local police and fire departments what the heck you thought you were doing.
This happened with a couple of guys I know, unfortunately I only got to see the end result (think crispy), because from what I heard it was quite the hilarious scene (in a bone-headed-move-of-the-year sense).
Ever had a gun pointed at your head while you're naked and half asleep??
Always wear goggles. I once was underneathe of my truck, and caught a piece of metal...rusty metal INTO my eyeball. Not on it, not underneathe of my eyelid...lodged IN my eyeball.
Scare tactic: I had to go to the optomologist, as I was having a hard time with my eye. NEVER RUB YOUR EYE WHEN YOU THINK SOMETHING IS IN IT. Even if you go to look in the mirror, and can't see it...it's there. First thing he did was sit me down, and check it out. The office was cool, and it wasn't hot outside. I had a short sleaved shirt on. He pulled the whole eye-looker-into-thing around, and shined light into my eye, and told me I had something in it. (no kidding). So, he tells me to stay still, he rolls his chair back, and I hear a drawer open. I can barely see through one of the open spaces in his giant eye observer, but I see him pull something out and place it on the desk...it's wrapped in a sterilized packet, and it made a heavy clanging sound when he put it down. He never showed me what it was, but I saw it as he came in, and told me to stay still. It was a needle pointed probe kind of thing...very intimidating looking. I felt a slight pressure against my eyeball. You know what it feels like to get a shot in your arm? It was like that, only in the eye. He was working on me for what honestly felt like 2-3 minutes...it was actually like 15 seconds. He would roll his chair out, and wipe the probe, and then come back. I was sweating bullets, like it was 120 degrees in there, when it couldn't have been 72. After his second trip to my eyeball, I had to back out of the eye thing and chin rest, and asked for drink of water. As he was doing that, a nurse walked by in the hallway, and I called to her, because I needed a trashcan to yuke in, and the doc was getting me water...luckily I didn't let one fly. He let me relax for a bit, and let me know that it was a common occurance. It has something to do with putting so much pressure onto your eyeball and throwing off your balance and equilibrium...then he got back to work. The whole thing took about 45 minutes, and after I got my eyedrops, I went to Home Depot, and bought 3 pairs of protective glasses. I had to go back two weeks later, to get checked on. His partner did the looking this time, and luckily it was only looking. She saw that I was a little nervous, and I asked her, "no poking around this time, right." She chuckled, and said Dr, So&so was 'so brutal', and that she normally uses the drill. I'm not adding comedy here....that's what she said to me. I chuckled uncomfortably, and asked her if there was a better way then the probe to take care of this, and she said, "yes, the drill." and looked at me like I was an idiot.
Lesson Learned: WEAR SAFETY GOGGLES
Point one: Finish small jobs. You will probably remember where you left off with big jobs (engine rebuilding, ect) but small jobs are easy to forget. The other day I was checking out my brakes when a friend called. I had the lugs on finger tight (it was still on the jackstands), dropped it and took off. When I took out th F-100 today, I forgot to retighten the lugs. They loosened quickly, and it became an interesting trip when I hit about 65mph. It was a long walk home to get my lug wrench.
Point two: carry tools with you at all times. When you don't have it, that's when you'll need it.
Point three: a 7 inch grinder and your leg will not get along if they meet. Ouch. And don't ever hold a piece of metal to the blade of a chop saw with your bare hand. Don't ask. It leaves a mark on your thumb you won't forget.
Point four: Don't drive when you're too tired to drive. Thought I could make it. Six days of no sleep, third shift work and auto work during the day didn't add up well. I was driving two hours a day in my 86 F-150 when I fell asleep. Triple rollover. I really miss that truck.
