'97 Explorer noise on deceleration
My son's explorer, 4.0 automatic, developed a problem during a 90 mile trip on the freeway. Driving along at 75 MPH with the cruise set everything seems fine. As soon as he lets of the accelorator the engine drops to idle speed and a noise comes from under the truck that sounds like an old siren, starts low pitch and gets higher and higher. The noise stops when he touches the accelerator applying power to the drive train.
The transmission shifts and pulls fine, no slippage. He said that for a while the 4WD light on the dash has been flashing six flashes, pause, six flashes.....a steady code.
Any questions or ideas?
Thanks
Thanks
not sounding good
first crawl under truck and check fluid in the t-case if full pull the rear sensor out (back of t-case) clean it and unhook battery this should fix your code....
second fin a steeeeep hill mountian )on black top road go about 60 mph let off the acellerator as the motor is
"braking the truck"pull it out of overdive into 3rd if the truck makes a grinding racheating noise I will be sorry to say your t-case is going south...I can fill you in more just get back in touch
ps ther is 5 diffent t-case for a 97 explorer
not sounding good
I think I found the issue. Looks like it is in fact the transfer case. I would not have thought so but.... See link below.
https://www.ford-trucks.com/forums/1...ing-sound.html
97 Explorer Transfer Case noises
I also ran into the same thing... a loud knock coming from under the car (which I originally thought was the tranny), then reverse slipped one day and the problem seemed to be gone. The exact "grinding/slipping" noise returned with a venegance and I needed a tow home.
Note: my truck wouldn't move in N or D or 4X4 High, but it didn't have a problem at all in 4X4 Low. After sitting overnight it started up and moved fine.
I don't doubt I have the same defect in my Transfer Case as explained in this thread, but I seem to have fixed the issue (for now) with draining and refilling the case with a Lucas Tranny additive and topping off to the bottom of the fill hole with ATF. Dunno what it did to the internal workings of the Transfer Case but all noises are gone and the car downshifts fine. I have especially tried driving in the the 40 - 60 MPH range which is where the issue seems to have been acting up the most.
Any thoughts?
Any thoughts?
Amber Hankins
08-17-2016 09:53 AM
