Sponsored by: Real Truck
6.2 worries
Old Feb 20, 2016 | 08:00 PM
f250truck's Avatar
f250truck
6.2 worries
I have a 2013 f250 4x4 with 154379 miles driving home last night my truck started making a popping noise and lost power for a moment check engine light starts flashing for a second then stopped after I let off then things were fine I don't have a code reader and live in the mountains anybody have the same problem
Old Feb 20, 2016 | 08:32 PM
99f350sd's Avatar
99f350sd
Get the code checked it may tell you what happened.
Old Feb 20, 2016 | 08:59 PM
Tom's Avatar
Tom
Hi F250truck, welcome to FTE!
Without knowing which codes were set we'd just be guessing. There are a hundred things that could cause a popping noise.
Old Feb 20, 2016 | 09:01 PM
FordmanNJ's Avatar
FordmanNJ
Yeah you need to get a code past or present. Pretty much all vehicles are this way. The code helps you figure out the problem more effectively.
Old Feb 20, 2016 | 09:03 PM
f250truck's Avatar
f250truck
Yeah I know without the code reader what I'm saying is pointless just the symptoms of what happened and if it had happend to them and maybe what they did to fix it .truck runs fine just trying to get an idea guess I need to buy a code reader
Old Feb 20, 2016 | 09:12 PM
99f350sd's Avatar
99f350sd
Go to autozone for free.
Old Feb 21, 2016 | 04:45 AM
Chuck's First Ford's Avatar
Chuck's First Ford
most auto parts stores offer a free OBDII scan.. with the code numbers.. a possible answer can be addressed.
Anything could cause your problem.. intermittent alternator to water in the fuel.
bad connection at 100 different electrical plugs.
but if the check engine light flashed and then went OFF... that means the problem was temporary... but could return.
if light is still on. . issue is SET. and must be addressed.
Old Feb 21, 2016 | 05:12 AM
gapman789's Avatar
gapman789
$20-30 at walmart. May as well buy one. It's a tool everybody should have in their toolbox.
Old Feb 21, 2016 | 08:38 AM
Bugzilla46310's Avatar
Bugzilla46310
Will be needing a code reader. What is the difference between the $30 reader and the $130 reader? Try to keep it layman's terms . Thanks
Old Feb 21, 2016 | 08:51 AM
Tom's Avatar
Tom
The difference is generally the capability of the tool.
All OBD scan tools can read P-codes, but everything else is extra. The cheap ones will just display the codes, but more money buys you freeze frame data, enhanced manufacturer-specific codes, live data, logging, etc.
The cheapest way to get the most functionality is a bluetooth OBD interface that uses your smartphone or tablet as a scan tool. Apps like Torque Pro can be had for less than $5 that give you all the functionality of an expen$ive scan tool. I paid $400 a few years ago for the AutoEnginuity Ford bundle, which is capable of live data, logging, manufacturer specific codes, and even the actuation of components controlled by the PCM.
The most recent use for me was about a year ago when I was having an ABS issue on my '97. No codes, but I was able to pull up live data of all four wheel speed sensors and spotted one that was dropping out at low speed. A low-end scan tool wouldn't have helped me there.
www.autoenginuity.com
Old Feb 21, 2016 | 01:40 PM
FordmanNJ's Avatar
FordmanNJ
I'm a big fan of getting something that can read ABS codes and data log for additional troubleshooting. A descent unit will allow you to download your data to a computer and even update the firmware for additional troubleshooting.
Old Feb 21, 2016 | 05:21 PM
f250truck's Avatar
f250truck
Ok so I got a scanner and it says it's code po308 which says it could be alot of things so looks like I will start with the plugs and wires
Old Feb 21, 2016 | 05:31 PM
gapman789's Avatar
gapman789
My 07 E250 Superduty van , 5.4, did that within the lst 100 miles of my 700 mile trip to Florida 2 wks ago. #6 coilpack and plugs.
Old Feb 21, 2016 | 05:38 PM
f250truck's Avatar
f250truck
Way past my warranty how much did it cost you
Old Feb 21, 2016 | 05:49 PM
gapman789's Avatar
gapman789
$171, parts and labor. Found a garage right where It started missing, pulled in 730 am, and on the road at 945 am.
I had a trailer full of motorcycles, and the van is a 15 passenger. I was loaded up for a week trip to Florida from Ohio.
But within 30 miles of coming back from Florida, flexplate blew apart. Theres another thread about that. lol.
