early frame design flat vs sagging (curved)
Old Jun 1, 2005 | 05:13 PM
MikeZealot's Avatar
MikeZealot
My question is WHEN DID F100s GO TO THE CURVED FRAME (SAGING IN THE MIDDLE UNDER THE CAB) RATHER THAN THE EARLIER FLAT/STRAIGHT FRAME ?
I'm working on an update to a 53 F100, I dont want to go to a M II front clip but rather use a later generation Twin I beam and disc brake setup. A 65+ is the desired, but how late can I go before the frame dips to lower the cab?
thanks
Mike
Old Jun 1, 2005 | 05:21 PM
ranger240's Avatar
ranger240
well 67-72 "droop" so if you know if the 65-66 don't or not that should be your best bet. however if you are going through the trouble, I wouldn't go with the twin I beam setup, there isn't much you can do with the suspension without spending a BUNCH of money. I would suggest scabbing in a LTD or MK-V IFS setup. it has a decent trac and can carry the weight. and for what it's worth......time being money and all......I'd just go with the mustang II IFS from Fatman's or something. measure it out and weld it in place (atleast that's what classic custom trucks wants us to believe).
Old Jun 2, 2005 | 12:05 AM
WillyB's Avatar
WillyB
I like the twin I beam, and do not trust a car type suspension on my truck. I am currently redoing a 59 and bought a 87 donor truck, mostly for the EFI engine. I am working on using its front end under the 59 so I can have PS and power disk brakes.
I am still measuring to see if I can make that work, but intend to scab the new frame onto the old one just in front of the front cab mounts.
Old Jun 2, 2005 | 05:17 AM
jowilker's Avatar
jowilker
Mike, The chassis from 65-79 are the same from the rear cab mount holes to the front bumper. The mid 70s would give you power steering and disc brakes.
My O, If you aren't gonna haul anything a car chassis should work fine. A working truck is a different animal.
John
Old Jun 2, 2005 | 09:34 AM
ranger240's Avatar
ranger240
I agree with jowilker, and I may add if you want a cruiser, you should go with a suspension better suited for it. even if you only plan on hauling a water heater or a load of landscape timbers from home depot, you really don't NEED a heavy truck front end. but if you already have it, and you are going to splice frames anyway....go for it. there are alot more parts available for the later model twin I-beams than the 65-79. so in reality that may be better for you anyway.
Old Jun 2, 2005 | 09:55 AM
WillyB's Avatar
WillyB
OOPs, didn't mean to step on anyone's toes - lots of people have used chrysler and other front suspensions with no problems.
I am going to be towing a camp trailer with a weight-distributing hitch so I want the heavier truck type suspension. I would also like to add power streering and power disk brakes without having to pay hot rod shop prices for them.
Old Jun 3, 2005 | 06:28 AM
jowilker's Avatar
jowilker
*****, Why don't you find a way to put the 59 on the 87 chassis. It'll take some fabbing, but could make a real dream to work with.
John
Old Jun 3, 2005 | 10:41 AM
WillyB's Avatar
WillyB
Originally Posted by jowilker
*****, Why don't you find a way to put the 59 on the 87 chassis. John
That was the original idea - I bought short wheelbase trucks so I could. I may still do that, but I understand the newer frame is not stright across the top rail and the cab will not sit right. I was told that if you lift the body enough for the frame and suspension to clear the hight of the truck is too high.
I am not sure, I need to spend the weekend measuring and thinking about which way to go with the project. I need to park them side by side on a cement slab and really look things over.
I have been driving the 87 donor for a few days and hope that the end project rides and handles as good as it does.
I was hoping someone would have done a simular project an would tell me how easy it was to do.
Old Jun 3, 2005 | 11:06 AM
ranger240's Avatar
ranger240
................pffft hahahahahahahahahaha you know better!!!
if it anything were easy, none of us would need the forum!! haha
I'm just kidding, I just got a kick out of that one.
Old Jun 3, 2005 | 11:12 AM
Huntsman's Avatar
Huntsman
Exclamation
The frame width is wider on the 89, the mid 70's frame was 34", which is the same as the 53-56 and possibly all the Ford frames through the seventies.
I have my 55 sitting on a 69 F-100 frame with the front I-Beams from a 75. The cab sits within an inch of the stock 55 height. The dip in the frame is between the front and rear cab mount and is not visible from the side view because of the running boards. Only problems so far is the front track width is a little wider than the stock 55, which I think can be controlled by possitive offset front rims.
As we all know, there are 3" dropped I-beams available that can drop the front a little, but never going to get the 'slammed' look out of it. The 87 frame being wider, would require channeling the older body to make it straddle the frame as it does in it's stock form.
rustywheel68
Dec 30, 2012 01:01 PM
3Mike6
Nov 28, 2004 07:04 PM
brucewolff
Oct 18, 2004 08:43 AM
grumpy1
Mar 29, 2004 06:31 PM
b1rdjx88
Apr 15, 2002 06:11 PM
