Cooling System Capacity
Old Jun 1, 2005 | 02:18 PM
Justforfishing's Avatar
Justforfishing
What is the capacity of the cooling system for the 1990 f-250 with the 7.3??
Thanks
Old Jun 1, 2005 | 07:20 PM
jboard's Avatar
jboard
Hi, just changed mine, think it took about 5 US gallons.
Jeremy
Old Jun 2, 2005 | 06:51 AM
diesel_988's Avatar
diesel_988
Hey Just, if you empty it out totally it takes 32 quarts U.S. with the heavy duty radiator. They pretty much all had the heavy duty.
Old Jun 2, 2005 | 01:14 PM
Justforfishing
ok - thanks! Is it OK to do a chemical flush on these motors??
Also, I bought the Napa Kool deisel additive but wasn't sure if it was the right stuff so I went to Ford and picked up their diesel additive. Is the Napa Kool Ok to use in a 1990 7.3?? Are they both compatible (if I use the ford stuff this time can I add the napa stuff when it needs more)??
Thanks,
Old Jun 2, 2005 | 03:19 PM
diesel_988's Avatar
diesel_988
Hey Just, THE NAPA stuff is good. Same thing. I've used the ford and CAT additives with no problems. Just test at every oil change to make sure you have the right amount in there. NAPA also sells the test strips for that.
Old Jun 2, 2005 | 03:22 PM
diesel_988's Avatar
diesel_988
P.S I've never done a chemical flush on mine, don't know if you can. I don't see any problem with it. I change out my anti-freeze yearly and flush the motor through the heater return hose 'till it runs clear.
racerx6466
Dec 22, 2012 03:36 PM
lowrider50
Jul 1, 2011 01:46 PM
Pest007
Aug 12, 2009 01:20 PM
john061543
20
Jul 2, 2008 12:18 AM
Bigyellowcat
Feb 17, 2006 11:02 AM
