Towing Capacity
Thanks in advance for any advice.
John
the way it's been explained to me, GVWR is simply the maximum your entire rig can weigh, including curb weight of tow vehicle, trailer and its contents, you and any passengers, your luggage, the flashlight in your glove box and the big gulp you got at the gas station. Take a glance at a late model 1/2 ton truck and its easy to see to remain "legal" you don't get to pull very much. That is, if I'm not way misinformed.
JML
As for towing/ hauling capacities, that's the GVWR minus the physical weight of your truck loaded to go, fueled up, with tools, cooler, you, whatever else in it. If the GVWR of your truck is 10,000 pounds (just as an example) and your truck, ready to go weighs 8,000 pounds (again, just an example) you have a legal truck payload of 2,000 pounds. That can either be hauled in the bed, or as trailer tongue weight. That's the legal definition as explained to me by a family member who's an attorney.
However, the DOT is a different story. Driving an antique half ton truck, I'd be amazed if you ever get hassled by them. They don't care about the GVWR on the door tag, they look at your actual weight and your license plate weights. For example: If your truck has regular passenger car tags, they probably have a legal weight limit of 8,000 pounds. If your truck and trailer, loaded physically weigh 10,000 pounds, you get a ticket for being overloaded by 2,000 pounds. It doesn't matter what your GVWR is, or towing capacity. To be letter by letter legal, your truck should have tags sufficient for whatever weight you intend to haul with it. In most states, the 'weighted' tags are commercial plates. Yes, super technically, grandma and grandpa towing their RV with regular plates on their pickup are illegally overloaded. However, unless you look commercial, you won't get hassled, and driving a antique truck usually doesn't look commercial.
When I had my PowerStroke, I was busted by the DOT for hauling metal culverts. I owned the truck and trailer, and I had purchased the culverts for private use on my property. However, since it looked commercial, I got pulled over and spot weighed with a portable scale. The entire rig with me in it hit just under 18,000 pounds and I was tagged for 26,000. No ticket. However, my '56 has regular passenger tags on it. The truck weighs about 5600, and I've hauled an estimated 14,000 pound load (farm tractor, implements, and trailer weight) with it once or twice. Aside from being a little bit of a scary ride, it's technically by the book overloaded.
Legally, any modifications you make to the vehicle are 100% irrelevant. You could drop your cab on a Kenworth frame and drivetrain, then register and tag it as an F-1. Legally speaking, you are driving a 1/2 ton pickup truck. However, modifications to hitches, the suspension, etc can be brought into play in a bad, bad way should you ever be in an accident and go to court. A friend of mine was in a nasty court battle after he hit someone towing a trailer load of hay. The plaintiff's attorney argued that since he had put air helper springs on his Dodge, he had intended to overload the truck and go beyond it's designed capabilities. The insurance company wound up settling it.
However, there aren't many options for a 50 year old truck. Fortunately, there usually aren't many people who will mess with you. Here in the next month or so, I'm going to be installing a gooseneck hitch in my truck. Naturally, there aren't any bolt- in options available, especially since it has the dump bed. It's going to be custom fabricated.
As for what your truck can tow, that all depends. Are the factory springs in it? I'd say try to find out what it was rated for when it was built, then go from there. More importantly than what you can get moving is what you can handle and stop. My truck gets a 14,000 pound load moving without too awful much strain. Stopping it with 4 wheel manual drum brakes (and trailer brakes) is a scary proposition. I won't be hauling that load again until I get power brakes and maybe front discs. The F-1 is light, too. The truck has to have enough weight to keep the trailer from wagging the dog, so to speak. Dual wheels help a lot, as does a gooseneck hitch compared to a ball.
That's the legal aspect of it, hope that helps. As for as what you can physically haul, I really don't know, but I'd guess way less than 10K. Just because you can get it moving doesn't mean that the truck can handle it and stop it in a panic situation. If you're doing 50 with a load and have to swerve sharply or stop right now, you need to know for sure the truck is heavy and strong enough to do it.
Just to clarify: I am not a lawyer, nor do I play one on TV. Consult an attorney in your state/ county to get a correct answer. What I have written is not legal advice. Please do not interpret it as such. Consult a licensed attorney with any questions you may have, as I am not one.
You'd be surprised how much plain old boring looking farm trucks get pulled over, or chased down for passing the weigh stations. Heck, every once in a while the DOT officers go ride up and down the state highways that bypass the scale on the state line. Not without good reason, mind you, but I wish they'd chase down the bigrigs with broken suspension parts and leave my little pickup truck alone.
If you don't have commercial plates, you do not have to hit the scales.
If you are going to be doing a lot of heavy trailering, make sure your tires are up to the task, standard pass car tires aren't up to the task. It goes nearly without saying you need electric trailer brakes on any trailer > 3K # GW and a good adjustable automatic brake controller.
(What 1/2-ton has a 7100 GVWR? it weighs almost 6,000 empty??)Do a websearch on towing ratings, you'll see that the Big 3 all magically jumped their towing ratings about 25% from the late 90's to current without any apparent change in equipment... Would anyone really want to tow even 6,000 lbs with a Ranger???
Out West we see flipped vehicles and dead bodies all summer vacation season from towing mishaps with relatively light travel trailers.
. got caught once while local weighing 125000 in a frameless dump , the stupidist thing i ever did though was give the wrong log book to the nice dot officer that pulled me over on rt. 24 in mo.
John
But what we're trying to determine here in the original question is what is it safe to tow in a Vintage F100 .
From my personal experience the trailer and set up you described above would surly have the tail wagging the Dog
as it applies to the original post.
So back to the original question, I wouldn't want to tow more than maybe 3500 - 4000 lbs at most at highway speeds with a relatively stock truck. There are a bejillion factors, but we're talking about some relatively flexible, lightweight frames, a Dana 44-like axle, and brakes that aren't super for heavy loads.
Willard will run a Jag IFS and a 72 F100 9 inch with a 350 Vortec and AOD. I have removed a couple of rear leaves but installed air shocks. If it doesn't like the hitch weight I may have to add back in a couple of leaves.
I would prefer to tow with a heavier and longer wheelbase vehicle but do not want to routinely drive a larger gas hungry vehicle or have an extra tow only vehicle. I typically tow about 1000 miles per year.
My trailer is aluminum with an aluminum space frame with a fabric top making it an enclosed trailer however it is only enclosed the width inside the wheels which works fine for the earlier running board cars that I move with the trailer.
