Universal Joints
Old Jan 8, 2013 | 02:49 PM
jeffreyt's Avatar
jeffreyt
Originally Posted by HH60FE
And chalk both your rear tires before you disconnect your drive shaft! I don't want to read about that again, haha
That sounds like its in reference to Smokiesman... His truck rolled right off the ramps and straight down the hill...
Old Jan 8, 2013 | 03:31 PM
F250_'s Avatar
F250_
Originally Posted by Lex2002
Ya lost me Mr.
"chalk" is actually supposed to be "chock".
Make sure to chock your rear tires on BOTH sides BEFORE disconnecting the driveshaft. You can also engage your e-brake as an extra measure of protection.
Forgetting that little detail above almost got me killed about 3 years ago, and I ended up with two broken bones in my left ankle before the truck came to a stop.
Old Jan 8, 2013 | 04:36 PM
Tugly's Avatar
Tugly
Make a column and label it FWIW. Under this heading, consider this: I took my drive line to a driveline shop... that's all they do, so they know their drivelines.
  • The greasable ones are logical, but they still don't last as long as the OEM sealed units.
  • We pulled my line and getting the old (265,000 miles) U-joints out took a hydraulic press, and even then they were stubborn.
  • He put it on the spinner and my driveshaft was way out of balance - and bent (visually confirmed by me).
Good thing for me that I took it to the experts.
Old Jan 8, 2013 | 04:41 PM
Lex2002's Avatar
Lex2002
Why did you take it to the shop to begin with Mr. Tugly?
Old Jan 8, 2013 | 04:57 PM
HH60FE's Avatar
HH60FE
Yes, thanks Pete, chock. Didn't want to mention names but these lessons we learn from others is valuable info.
Old Jan 8, 2013 | 05:24 PM
Red97350's Avatar
Red97350
The way I did the old u-joints on my old F250: Get grease-able u-joints and take the grease fittings out. When you are getting ready to install the u-joints, take the caps off and pack them with grease so the needle bearings won't fall out. When you press them in to the yoke, the extra grease will come out of the grease fitting hole. Seemed to work well for me.
Red
Old Jan 8, 2013 | 10:16 PM
Tugly's Avatar
Tugly
  1. There's snow on the ground. You know... under the truck.
  2. It's friggin' cold outside this close to the Land of Labatt
  3. There was a vibration in my truck and the driveline passed all the normal tests... so something more sinister was up.
Old Jan 9, 2013 | 04:47 AM
2000ca250's Avatar
2000ca250
When I did mine I just pulled the rear shaft (my rear u-joint was shot, the others were fine) put the yoke in a bench vice with a socket that was smaller than the hole in the yoke on one side, and a socket that was bigger than the cap then just tighten the vice down. Worked like a charm. I will add though that it was definitely something that gave us a little problem with the new bearings falling out. Pack them with grease, and be careful. Pretty easy job.
Old Jan 9, 2013 | 07:56 AM
F250_'s Avatar
F250_
Not a problem. I honestly don't mind anyone knowing about or referencing my screwup which ended up requiring 8 screws in my left ankle! If someone else can learn and avoid damage/harm by reading about my own experience, please feel free to share it with anyone you want.
Old Jan 9, 2013 | 08:15 AM
Snowseeker's Avatar
Snowseeker
It was probably bent form the press. I use a hammer and only a hammer to change joints. I can easily say I have changed over 100 U-joints. Greasable ones are good, I like the brute force joints, no grease zerk but they last like OEM.
Old Jan 9, 2013 | 08:56 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
When I had my driveshaft balanced I asked the shop owner if he used a press to take out the u-joints and he said "never." He always uses a hammer.
Old Jan 9, 2013 | 09:22 AM
Lex2002's Avatar
Lex2002
Snow...oh that's that white product which falleth from the heavens, yes?
So the universal joint was causing this vibration? Was there any associated noise? Whine?
Old Jan 9, 2013 | 09:40 AM
  #28
Lex2002's Avatar
Lex2002
.... I like the brute force joints, no grease zerk but they last like OEM.
OH thanks for this recommendation Mr. Snowseeker.
Old Jan 9, 2013 | 01:06 PM
  #29
Tugly's Avatar
Tugly
No whine or growling. Upon removal of the U-joints, only one had... uh... bernelling or whatever it's called. It wasn't very serious. The vibration was pretty intense, though... and the work definitely took the vibration out. I assume it was the imbalance and bend in the driveshaft that was my key problem. That's not fixed with new U-joints. I have since moved on to the next three problems.
Old Jan 9, 2013 | 01:12 PM
  #30
Lex2002's Avatar
Lex2002
Thanks for the reponse Mr. T.
How does one check for a bad universal joint? Will it have play in it if you shake it or pry it with a pry bar?
A
