No "BRAKE" light when E-brake is set
Old Apr 7, 2009 | 03:13 PM
superduty4x4's Avatar
superduty4x4
Could just be the bulb in the dash is burned out, switch seems okay. Since my truck is an auto I never use the e-brake, but the AIC I installed requires the e-brake to be set before it can do it's thing. Where to start troubleshooting?
Old Apr 7, 2009 | 03:19 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Does the AIC use the bulb or the switch to make it do it's thing. Is there power going to the switch, and power going to the bulb when the pedal is pressed? Sounds more like the switch to me. Or fuse.
Old Apr 7, 2009 | 03:22 PM
superduty4x4
I think the AIC relys on the bulb, not the switch. I didn't volt test the switch... it's a single wire jobber and the switch actually moves when the brake is pressed so I assume it's fine... didn't check fuses
Old Apr 7, 2009 | 03:31 PM
triskit16's Avatar
triskit16
AIC?! Im having a brain fart...
Old Apr 7, 2009 | 03:37 PM
superduty4x4
aux. idle control
Old Apr 7, 2009 | 03:46 PM
miller_feed
Single wire, does it ground when the pedal is pushed. I don't know how a single wire switch would work.
Old Apr 7, 2009 | 03:54 PM
superduty4x4
No idea Rick. I'll have to mess around with it when I get home. I'm half tempted to have someone on one of the other forums I frequent play with his AIC and figure out what tells the AIC the brake is set and mod the thing to think the e-brake is always on.
Old Apr 7, 2009 | 04:05 PM
miller_feed
Good idea, you could alway use it as a cruise control.
Old Apr 7, 2009 | 04:16 PM
Ponyboychris's Avatar
Ponyboychris
Maybe Jim (Megawatt) has a wiring diagram...
Old Apr 7, 2009 | 05:07 PM
triskit16's Avatar
triskit16
Ill share some insight I have. In dash tv's I used to install would usually have a wire that needed to be connected to the e-brake to make sure you werent driving while watching the screen. I used to wire it up so they could watch it while driving but only if they forgot where they bought it!
I wired the "wire" to the chassis ground wire in the harness and that was that. It only needed to be grounded to work. Im pretty sure they are working off the same principal.
Old Apr 7, 2009 | 05:24 PM
superduty4x4
So just hook the wire off the e-brake sensor to ground and call it quits? Sounds easy enough.
Old Apr 7, 2009 | 05:55 PM
triskit16's Avatar
triskit16
Thats what I did with the car stereo stuff. Im pretty sure the e-brake just creates a ground and completes the circuit, thus usually lighting up the bulb. It could be the other way around as well, but I doubt it. I know Jim does have access to the wiring diagrams so you might want to hold off just in case. I cant ever get into that site anymore!
I also dont know if there is some switch that you use to activate the AIC or if that ground activates it. If the e-brake would be used to activate it, I would hook it to the e-brake!
Old Apr 7, 2009 | 06:02 PM
superduty4x4
AIC plugs into a factory plug under the dash... in order to "activate" it you have to be in park with the e-brake set (or in neutral with e-brake set for a handshaker) with the light in the dash on... no light = no AIC function. It turns on and displays rpm and voltage, but won't activate any of the high idle programs w/o the light. I'd really like to figure out what inside the AIC tells it the brake is set, and solder a resistor or whatever is needed in so that it always thinks the brake is set.
Old Apr 7, 2009 | 06:09 PM
triskit16's Avatar
triskit16
Im still gonna say e-brake just completes a ground, but wait on Jim! Not worth ruining the AIC IMO!
Old Apr 7, 2009 | 06:15 PM
superduty4x4
I don't think by grounding the wire at the e-brake sensor it would ruin anything, but I will put my tester to it when I get home tonight and see if it has juice in it or not.
