Pittman Arm
Old Dec 28, 1999 | 09:46 PM
Moe Gendron
Guest
Posts: n/a
Pittman Arm
Hey Ya'll,
I've got my suspension apart and I'm wondering if a Pittman Arm is supposed to have any movement at all in it. Mine is not "sloppy" just a very,very small amount of play. Should I replace it too? I'm doing this on a 85 F150 2wheel drive. Seems to me even a small amount might seem larger at the steering wheel.
Thanks,
Moe
Old Dec 29, 1999 | 10:20 AM
PAUL_2's Avatar
PAUL_2
Pittman Arm
Moe ,
Id say if you have it all apart , replace the pitman arm ...It doesnt take much slop in the steering dept to make the difference in handling .
Paul
Old Jan 27, 2000 | 02:14 AM
SPLabar's Avatar
SPLabar
Pittman Arm
Replace it. The slop in the splines will cause wear on the steering box shaft. The arm is cheaper and easier to replace than the steering shaft. The shaft is tapered is you will see when you get it off. The nut on the shaft pulls the arm in and wedges it on, the splines increase the surface area of the joint and keep it from slipping, but it is the tension the nut puts on it that keeps it in place, just like a ball joint. You have lost that tight fit and it is just a matter of time before something happens. Replace it and feel assured that the splines won't strip while your doing 70 down the interstate.
Old Jan 27, 2000 | 08:21 AM
Phillip Guidry's Avatar
Phillip Guidry
Pittman Arm
fordrealdrive
Offroad & 4x4
75
Sep 19, 2016 02:07 PM
ob_one
May 28, 2012 07:49 AM
papajoemrt
1997 - 2003 F150
15
Nov 29, 2008 01:10 AM
peabo
1997 - 2003 F150
Feb 4, 2002 05:51 PM
webdane
Nov 23, 2000 06:03 PM
