oil filter ?
Old May 31, 2005 | 06:25 AM
e g rred's Avatar
e g rred
oil filter ?
My son's 01 Ranger calls for Motorcraft 820s oil filter and I was wondering if an FL1-A would be okay ? I know it is longer and would hold more oil , but the threads and gasket are the same . thanks in advance
Old May 31, 2005 | 07:22 AM
Help I M Stuck's Avatar
Help I M Stuck
as long as the threads are the same and the rubber seal mates flatly against the spot on the engine block..then you are ok...just check the oil and add the little extra.
Old May 31, 2005 | 12:06 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
The threads and gasket may be the same, but the physical space being occupied by the filter may not be. I tried with a Bronco 2 and there was just no way it was gonna happen.
And if your son's 01 is a 3.0 you can pretty much forget about it.
Old May 31, 2005 | 01:40 PM
e g rred's Avatar
e g rred
Thanks for the reply - its a 4.0 but the filter hangs straight down so I wondered why the longer filter would not work------------ thanks again
Old May 31, 2005 | 05:26 PM
J McGuire's Avatar
J McGuire
My son also has an '01 Ranger w/4.0L and he has been using the FL1 for the last two years without problem. I have put the FL1 on a 3.0 that I had, only because I didn't realize I had no 400s until I discarded the one I took off. Yeah, there is not much room for it on the 3.0 but it fits there too.
Old Jun 1, 2005 | 07:32 AM
pawpaw's Avatar
pawpaw
I wonder if the longer FL-1A maybe sits too close to the exhust & might run too hot there & "cook" the oil????
I know my 99 4.0L is specified with the FL-1A & it's top shure hangs close to the exhaust & gets plenty hot there. Seems to me it needs a heat shield, sorta like they put on the tranny case on the 4.0L.
Old Jun 1, 2005 | 12:43 PM
GWIGG's Avatar
GWIGG
I didn't know you could use the FL1A in place of the FL400S on the 3.0 engine. I haven't tried it, but they are different in diameter. The FL1A worked on your 3.0? Just asking!
Old Jun 1, 2005 | 01:49 PM
J McGuire's Avatar
J McGuire
Reply to GWIGG Yes, I have used the FL1A on a 3.0L . I already had an '93 Ranger with a 4.0L and had several oil filters on the shelf. When I purchased the 3.0L I just assumed that they used the same filter. When I went to change the oil & filter I noticed the small filter and assumed (again) that the other guy used the wrong filter. When I finished and cleaned up THEN I looked in the manual (doesn't everybody do that?) and found that I had used the wrong filter. It fit and did not leak so I left it for the next 3,000 miles. Removing the 400s is bad enough...the FL1A took a little longer.
Old Jun 2, 2005 | 01:58 PM
PW01's Avatar
PW01
I was also wondering about the Motorcraft filter size for the 01 SOHC 4.0. Whatever you do, skip the Valvoline brand filter (V-047) because half the ones I've used leak at the seal.
Old Nov 16, 2005 | 05:55 PM
Fordsflylow's Avatar
Fordsflylow
I use Motorcraft Fl-1A filters on my 94 Ranger w/4.0L and it has done great until my last oil change, which turned into a bunch a nightmare.
I went through my usual process, put oil around the seal of the new filter before installing, and filled the filter with fresh oil partially to reduce the dry start, then hand tightened 3/4 a turn. Filled it and fired it.
Went back to the motor to look for leaks around the filter and it was blowing oil completely around the seal area. By the time I got back to the cab to shut it off she blew out over 4 quarts and oil pressure never did register on the gauge.
I have had my truck for 8 years and 145000 miles and not one problem. Now I have a terminal tap when she's cold.
I'm rippin mad about it!! I still have the faulty filter which must have a defect to not have tightened/seated normally. Not sure what, if anything, I can do about it (i.e. warranty, liability, etc.). A motor teardown isn't going to be cheap!
Old Nov 16, 2005 | 06:12 PM
ColonyPark's Avatar
ColonyPark
Correct me if I'm wrong, but the "S" designation indicates a silicone anti drainback valve, as opposed to the old black rubber, right? I know that silicone is more flexible over a wider temperature range. That might be important on a vehicle that specifies a silicone anti-drainback valve.
Old Nov 16, 2005 | 06:30 PM
pawpaw's Avatar
pawpaw
Did by chance, the old flters seal come loose & stick to the oil filters mounting base & you just missed it, when you screwed the new one on top of it, or is there a crimp problem around where the filters can is crimped to it's base plate????
Old Nov 17, 2005 | 05:02 AM
Fordsflylow
Nope! Always make sure to get the old rubber seal ring off if it didn't come off with the old filter. Also clean the area off the adapter where it seats before installing the new one. I can't see any problem with the faulty filter on the outside, it must be on the inside.
hydrosmith
1978 - 1996 Big Bronco
Feb 28, 2011 05:34 AM
mblanken881
Jan 10, 2009 07:58 PM
razormac
29
Jan 11, 2007 06:13 AM
schjssj
Nov 23, 2006 11:53 AM
MisterCMK
Oil & Lubrication
Jul 30, 2003 08:15 AM
