Dash Lights-Improper Ground?
Old May 31, 2005 | 05:51 AM
PJJUN's Avatar
PJJUN
I'm still trying to get my dash lights to work properly. I've replaced the instrument back panel, the printed circuit board, the bulbs, but the llights still do not work. I do have turn signals and guages, and the "ALT" light comes on at start-up (normal). The fuse is OK.
Somebody suggested that I have a bad ground. How would I go about tracking this down and fixing?
Old May 31, 2005 | 10:42 PM
LxMan1's Avatar
LxMan1
If the turn signal and alt. light work, then the panel has a ground to the printed circuit. Do you have 12V to the fuse when the lights are turned on?
Old May 31, 2005 | 10:50 PM
Mil1ion's Avatar
Mil1ion
Have you turned the headlight switch to brighten the lights on the cluster ?
Inst lights Fuse ?
Old Jun 1, 2005 | 07:23 AM
PJJUN's Avatar
PJJUN
I'll check. Thanks for the help.
Old Jun 1, 2005 | 07:25 AM
PJJUN's Avatar
PJJUN
Yes, the lights are on and the level of the dash illumination is at the brightest level. I think I'm going to replace the fuse (even though it appeared to be fine before) to see if that does the trick. Thanks for the input.
Old Jun 1, 2005 | 09:28 AM
73Custom's Avatar
73Custom
There are dash lights for the stock radio, heater controls and headlight/wiper ***** - do these work on your pickup? If not then the problem is the headlight switch or wiring. If they do work, then the problem is with the cluster or cluster connector.
Marty
Old Jun 1, 2005 | 01:10 PM
PJJUN's Avatar
PJJUN
Well, some of those lights were working before I started this little project; not all.
Old Jun 1, 2005 | 01:38 PM
Mil1ion's Avatar
Mil1ion
Do you have a multi-meter ?
You will probably need one
Old Jun 1, 2005 | 01:42 PM
73Custom's Avatar
73Custom
If I remember correctly, the dash light circuit is the blue wire with red stripe. Find this wire in the wiring connector for the guage cluster and test it for power with lights on - use a test light or mulit meter. Tell us what you find.
Marty
Old Jun 1, 2005 | 05:23 PM
docholiday72tx's Avatar
docholiday72tx
I don't mean to hi jack a thread, but I have a similar problem. My fuse for the dash panel lights blows everytime I turn on my head lights. I pulled off my guage bezel and went to looking around and noticed my head light switch is getting realy hot. Would this be a bad switch, or wiring problems.
The head lights, tail lights, turn signals, side marker lights, all work. My cigarette lighter, radio, and wind shield wipers work. Everything works except the dash panel lights, and all of them are out.....head light/wind shield wiper light, guage lights, and A/C heater control light.
Mike
Old Jun 1, 2005 | 05:33 PM
LxMan1's Avatar
LxMan1
Does it have an aftermarker radio in it? Sometimes the light wire to the original gets left hanging and grounds out. Yes the instrument lighting wires are light blue with a red stripe.
Old Jun 1, 2005 | 06:14 PM
docholiday72tx
Mine has an aftermarket radio, but I used the factory wires to wire mine in so there are no loose wires.
Mike
Old Jun 1, 2005 | 07:11 PM
Mil1ion's Avatar
Mil1ion
Have you tried un-plugging the cluster from the harness & pull the lights on to see if the fuse blows with the cluster dis-connected ?
It usually take about 4 fuses to find out which circuit it is (if you don't have test equipment)
Old Jun 1, 2005 | 07:36 PM
docholiday72tx
I unplugged the cluster and still have the same problem.
Old Jun 1, 2005 | 07:54 PM
Mil1ion's Avatar
Mil1ion
Next, disconnect the power to the radio & ashtray light if it has one.
I assume it blows when the switch goes into the park light position ?
http://www.clubfte.com/users/mil1ion...lusterBack.JPG
