Dash Lights-Improper Ground?
Old Jun 1, 2005 | 10:07 PM
PJJUN's Avatar
PJJUN
Mine has the original radio. Works fine.
Old Jun 2, 2005 | 07:50 AM
docholiday72tx's Avatar
docholiday72tx
Guys, I found my problem. I replaced my fuse to the guage lights and unplugged components until the truck didn't blow the fuse any more. I started from the left side and worked to the right. When I got over to the stereo harness and unplugged it, the truck quit blowing the fuse. On carefull inspection I found a place where the blue wire with the red stripe had a bad place in the insulation. I taped up the wire and plugged it back in, and everything worked. I also found that the only way the dash lights would come on was to turn the headlight switch all the way to the left to where it clicks and the dome light comes on. I replaced the headlight switch, and now everything works like it should.
Pjjun, Does your truck continuously blow the fuse or is the fuse still good but the dash lights still don't come on?
Mike
