Cowling Munge
Old Jun 1, 2005 | 02:25 PM
Phideaux's Avatar
Phideaux
Cowling Munge
I live in an area where there's a lot of pine needles and such which always find their way into the cowling below the windshield.
Obviously the cowling ain't removable on this model Truck. (Cxevy Trucks have 4 small body bolts and the cowling comes right off.....Sniff).
In the process of restoring a 78 F250 that's totally impacted w/ pine needles leaves, mouse nests etc. Alternating compressed air and water ain't getting it out.
Anybody been there and done this before? If so, how?
Thanks,
J.
Old Jun 1, 2005 | 02:32 PM
whd507's Avatar
whd507
lots of water, and a yardstick. pull out the interior vents.
Old Jun 1, 2005 | 07:17 PM
Mil1ion's Avatar
Mil1ion
You need to place a piece of stiff cardboard re-direct in the center of the cowl when you use the air.
If you lay some plastic wrap across the cowl & use a powerful shop vac in an open spot ,that usually works too.
Old Jun 1, 2005 | 07:22 PM
bulrydr_1's Avatar
bulrydr_1
It's a frustrating job! I got a little flustered and cut out the middle slats, and used air and a vaccum, then welded them back. Probably not the best way to do it, but mine sat under these carolina pines for about 2 years before I bought it and it was driving me nuts...
Old Jun 2, 2005 | 09:43 AM
whd507's Avatar
whd507
I had a perfect cab, but it was rusted in that valley, so I cut the whole cowl out, and repaired it, then welded it back in. I considered finding removable vents like from an old Jeep, and keep it accessible, but I just welded another cowl panel in there.
a restricted grille like the 92-97 F-series with tiny holes would have been better in my opinion.
