What plugs????
Old May 30, 2005 | 11:44 PM
eindow's Avatar
eindow
What plugs????
I need some help on choosing what type of plugs to use on an 1999 explorer 5.0 w/ 100hp shot of nitrous??? I want to go with 1 step cooler plugs could anyone help????
thanks...
Old May 31, 2005 | 08:04 PM
Blurry94's Avatar
Blurry94
NGK plugs work well for boost and spray and you can pick them up at most auto parts stores.
Old Jun 1, 2005 | 01:01 AM
eindow's Avatar
eindow
thanks I was looking into those...
Old Jun 1, 2005 | 11:26 PM
FTE Herman's Avatar
FTE Herman
I like the Denso's, but at $12 a piece, a little pricey.
Old Jun 2, 2005 | 09:08 AM
Fredman's Avatar
Fredman
Nothing wrong with Motorcraft Copper plugs. I know a lot of boosted guys that run them with no problems. They are less than 2 bucks a piece and you just can't beat them.
Marlon
Old Jun 6, 2005 | 11:39 PM
Countrykid's Avatar
Countrykid
I personally would go 2 steps colder, retard the time, and maybe a window switch for safety. And I hope it's a wet kit...right.
Old Jun 7, 2005 | 12:50 AM
Blurry94's Avatar
Blurry94
I've had some idle/driveability issues with a plug that was two steps colder.
I also used the Ford plugs and blew the spark out at higher RPM's. Tried gapping them closer and that didn't help.
Old Jun 8, 2005 | 06:32 PM
eindow's Avatar
eindow
Yeah it is a wet kit and I've been running a 75 shot with the motorcraft plugs.
I went ahead and bought the ngk-7317 plugs off summitracing.com for $2.39 each those should work fine thanks everyone...
Old Jul 8, 2005 | 09:15 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I use 0.4mm Denso Iridiums. Not cheap, and need to be replaced regularly, but they work extremely well.
I would really like 2 spark plugs per cylinder, but thats not going to happen, and these do a more than acceptable job.
Old Jul 9, 2005 | 10:09 AM
Wekiwa's Avatar
Wekiwa
Check out the 4 electrode plugs. We've never had a problem with "flame-out" at high rpm or boost.
I'm sometimes relectant to provide a little trick like these plugs because it may be the missing variable to allow you to blow it up! but hey, my family and friends did it for me so why not continue the tradition....
Wekiwa
