Check Engine Light and Jumper Wire
Old May 30, 2005 | 06:15 PM
swhite005's Avatar
swhite005
The following site tells how to set up the wire, but doesn't say what to connect it to...
http://www.corral.net/tech/maintenan...vtest.html#two
What do I plug the homemade jumper wire into in the vehicle to retrieve the codes?
Old May 30, 2005 | 07:44 PM
maa139's Avatar
maa139
There's a technical info sticky thread in the top of the Ranger forum with instructions. If you have one, there's also instructions in a Haynes manual.
Matt
Old May 30, 2005 | 07:45 PM
ledbetter's Avatar
ledbetter
What year vehicle do you have? I'm not sure if that method will work for newer models (95 or 96 and later). If your check engine light is on, you can take it to autozone or other parts store to have them read codes for free.
Old May 31, 2005 | 12:41 PM
mrshorty's Avatar
mrshorty
Correct. That method only works for EEC-IV/OBD-1 equipped vehicles. OBD-2 was required starting in '96.
Benchwrench
Oct 26, 2016 03:12 AM
RustyTrustyF150
Sep 30, 2015 09:32 AM
frankx
1978 - 1996 Big Bronco
Oct 30, 2014 12:07 AM
blueeyedfordguy
Electrical Systems/Wiring
16
Apr 19, 2010 10:42 AM
rich250
Dec 24, 2007 03:55 PM
