Trans/clutch problem??
Old May 30, 2005 | 09:10 AM
padd54's Avatar
padd54
This simple rear wheel seal replacement keeps getting better. I have the rearend on jack stands, with the trans in neutral, the wheel turns. I can stop it with my foot but it will start moving again. I have tried to adjust clutch fork to where there is no play at all and to where it is sloppy loose. No problems shifting through gears, except I think the throw out bearing my be going. How much play shold there be on the clutch fork? Only one wheel turns on the jack stands, but when I get on it, it will spin both tires in gravel and on blacktop.
Thanks for the help.
Old May 30, 2005 | 10:25 AM
4Cammer72's Avatar
4Cammer72
i think if you had other cars to compare to you would find most manual trans vehicles will do the same thing on stands. it;s kind of like spinners on rims. you will get some rotation of the wheels even in neutral with it sitting on the stands. its kind of a residual friction coming through the drivetrain.
peter_x
Aug 14, 2012 01:50 PM
Blackbeltdually
Jul 29, 2010 04:15 PM
NewRed
Feb 18, 2009 09:34 PM
wickedinhere
Feb 10, 2009 01:44 PM
