5 speed Close Ratio
Old Feb 2, 2000 | 05:12 PM
Tyler's Avatar
Tyler
5 speed Close Ratio
Here's what I know, Ford used 3 different ratios in the "ZF-S5 42" 5 speed. The wide ratio (5.72 first gear), and two close ratio models, (4.14 and the 5.08 first gear). The 5.08 being the later model. Does anybody know when Ford switched? I pretty sure it was near/after power stroke was introduced.
Thanks
Old Feb 3, 2000 | 10:04 PM
Trail_Rider's Avatar
Trail_Rider
5 speed Close Ratio
I don't know about when they changed but I will tell you this. Ford used a different 5 speed in their 1/2 tons and 3/4 tons. I had a '94 1/2 ton with a 6 and a 5 speed that had great hiway gears but no bottom end. I traded it for a '94 3/4 ton with a 351 and a 5 speed. That one was geared like the old 4 speeds but with an overdrive. Hope this helps.
Trail Rider
Old Feb 3, 2000 | 10:50 PM
PAUL_2's Avatar
PAUL_2
5 speed Close Ratio
97puller
Dec 23, 2013 05:36 AM
OldWoodsDiesel
19
Nov 14, 2012 09:10 AM
TIKT B8
Sep 1, 2010 09:13 PM
CheaperJeeper
16
Jan 30, 2007 02:04 PM
Clifford II
Apr 18, 2004 11:54 AM
