ZF 5 speed question
Old Dec 21, 2013 | 05:07 PM
97puller's Avatar
97puller
ZF 5 speed question
Is it possible to swap the gears from an the close ratio S5-42 into a wide ratio S5-47? I do some truck pulling and need the faster 2nd gear.
Old Dec 22, 2013 | 01:05 PM
EPNCSU2006's Avatar
EPNCSU2006
I think that it might be possible to alter the ratios some if you can disassemble the countershaft and press (shrink-fit) new gears on the countershaft to go along with different gears on the mainshaft. I don't think you will be able to swap the whole gearset because in addition to having a different tooth count on the input gear, the pilot and clutch spline area is also different between gas and diesel versions.
Old Dec 22, 2013 | 02:55 PM
Diesel_Brad's Avatar
Diesel_Brad
I am assuming you are talking diesel?
If so and you have a s42 to swap gears sets from, just use the whole trans
Old Dec 22, 2013 | 04:37 PM
97puller's Avatar
97puller
i have 460 gas truck. the 2.37 2nd gear from the close ratio diesle trans would put my final ratio right about where i need it.
Old Dec 22, 2013 | 09:06 PM
Diesel_Brad
O. NO you can NOT mix and match gears. you can swap ALL the gears, but not individual ones
Old Dec 22, 2013 | 11:12 PM
Macrobb's Avatar
Macrobb
IIRC, the bellhousing on the 7.3 idi and 460s was the same, so you could bolt one transmission up to the other... though, I think some bolt holes don't exist in one side or another, so you might have to do some drilling/tapping.
Old Dec 23, 2013 | 05:36 AM
Diesel_Brad
NOPE. not the same. Have to drill new holes and open up others
calazo
1978 - 1996 Big Bronco
15
Apr 30, 2010 03:48 PM
wycowboy
18
Nov 27, 2005 09:34 AM
why165
Jan 19, 2005 07:56 PM
Paul Crowther
Nov 24, 2004 09:17 PM
