mixture settings
Old May 30, 2005 | 12:14 AM
rkent5469's Avatar
rkent5469
mixture settings
i need to set up a edelbrock 4 barrell carb how would you do that properly
Old May 30, 2005 | 07:58 AM
lee's Avatar
lee
Hi,
The short answer is: Hook a Vac gauge up to a manifold source and adjust the mixture to the highest Vac reading. Then adjust the idle RPM. Repeat steps 1-2.
Lee
Old Jun 1, 2005 | 01:00 AM
beeboy's Avatar
beeboy
also depends on what you want to adjust? Idle, cruise or power mixture?
Old Jun 2, 2005 | 12:03 PM
nsaikia's Avatar
nsaikia
When you say intake vacuum source, will the port for PCV in the carb work? In my 302, I cannot seem to understand where I will get intake vacuum. Also, I do not see any PCV valve or hose comming out.
Old Jun 2, 2005 | 05:27 PM
lee's Avatar
lee
Hi,
Yes, the port for the PCV will work just fine.
Also you could use any port on the carb that is below the throttle plates.
Your PCV valve should be located in a gromet on one of your your valve covers. It would then have a hose going from the valve to the carb.
Lee
wb6anp
Nov 6, 2016 08:05 AM
tetsuo73
Jan 28, 2014 04:48 PM
ksmith203
WTB - Parts & other
Nov 30, 2013 01:59 PM
Special Ed
Feb 11, 2012 10:45 PM
05excursionred
Feb 12, 2011 10:44 PM
