torque setting for camshaft sprockets
Old 01-28-2014, 01:20 PM
tetsuo73's Avatar
tetsuo73
tetsuo73 is offline
Anyone knows the setting for 2003 ex v10?
thanks
Old 01-28-2014, 03:45 PM
Archion's Avatar
Archion
Archion is offline
According to AllData
Camshaft Pulley/Gear Torque
M10 Bolt: Tighten in two stages.
- Stage 1: Tighten to 40Nm (30 ft lbs.)
- Stage 2: Tighten an additional 90 degrees.
M12 Bolt: Tighten to 120Nm (90ft lbs).
Old 01-28-2014, 03:47 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
On engines equipped with bolt-on sprockets, install the camshaft sprocket (2).
Install the bolt (1).
Tighten the bolt.
M10 bolt: Tighten in two stages.
Stage 1: Tighten to 40 Nm (30 lb-ft).
M12 bolt: Tighten to 120 Nm (90 lb-ft).
Old 01-28-2014, 04:48 PM
tetsuo73's Avatar
tetsuo73
tetsuo73 is offline
Thanks for the fast respond guys!
can't wait to put the things back together.
Bonanza35
03-04-2011 10:56 PM
Snobord28
10-13-2010 12:54 AM
jvmcc
12-04-2004 07:37 PM
Rat wagon
04-04-2003 09:38 AM
Quick Reply: torque setting for camshaft sprockets
