View Poll Results: Have you done the KWIK 6637 MOD?
Voters: 112. You may not vote on this poll
Have you done the KWIK 6637 mod?
#46
Originally Posted by f-troup
Thiking of doing the 6637 MOD, should be able to get a 45*x4" pvc elbow at Home Depo. That would make it easier to mount the sensor in to monitor the temprature. Has any body done this?
http://community.webshots.com/photo/...06574455eGtEWG
here's a pic of my intake, the elbow right after the filter has a real nice, flat, thick spot right on the top that would work, I left it untouched for a propane nozzle to fit into some day.
Diesle Rod
#49
Originally Posted by empiretc
looks like youre a little low on brake fluid there, lol
good looking mod. ill have to take a pic of mine and post.
But it's right at the full line ( I had to suck a bunch out when I did my front brakes last week)
#50
Originally Posted by 444dieselrod
most zip tie it to the fender wall, or the brake line. mine is stuffed into one of the holes in the fender.Diesel Rod
Get it as close to the flow of air as you can and away from heat.
#51
#52
Originally Posted by Steve_250
One problem with stuffing it in the fender wall is heat. Summer is here, if you have a dark color mule the fender will be HOT and it will read incorrect ambient temps. (JMO)
Since I don't have an AIC, I gutted the EBPV, and its summer, I never use the GP, it really isn't important for me, some people it might be, if they have these features
But you are very correct that a dark vehicle, the '97 is black, it will give a false reading. that thing cooks in the summer.
Diesel Rod
#54
Well,
I did mine the other day and saw an improvement in the MPG. Today I went out and took it back off to drill out the exhaust pipe for my filter minder. I was concerned about it not fitting well due to the curve of the pipe buit it is really snug, no leaks there.
One observation I did make was with the old filter box. If there is any doubt about doing this mod this should open up your eyes!!!!
While holding the complete assembled factory box in my hand to take out the rubber gasket for the filter minder something inside of the air box caught my eye. It was a glimmer of light. Upon closer inspection I noticed that the top of the air filter cover where the tabs fit into the lower halve has a noticicle gap alll along the edge. The cover was in place, and the filter was in the assembly and the tabs were pushed in as far as they would ga and the cover latched!!!
Now, if I can see light, on the turbo side of the filter, then I can assume that dust would also be able to get sucked right in.
In closing, if you were sitting on the fence like me trying to decide whether or not to do this mod, look at your own filter assembly off of the truck. Maybe you too will "see the light"!!!!
#56
I just ran my first tank through after doing it, 19.54mpg, so there was a definate improvement even though I "got on it" a little more than normal.... The best I ever got before was 18 (after gutting the cat and trash-canning the muffler) and the worst was 16 ... I'll be keeping logs as I mod to see what works and what doesn't.
#57
#58
#60
Originally Posted by cangim
In an earlier post someone posted that they where getting white dusting particles from the filter, made me wonder so I had to go and check mine out. Mine is clean as a whistle, I am very satisfied with my filter intake setup.
I wish I had taken some pictures. As I stated before, the dust could have been from the manufacturing/boxing/storage of the filter. I simply cannot prove my theroy however.
I'm having a hard time nailing down the reason for my loss of mpg with the filter. It's possible that my recent front end alignment may have corrected that problem.
I still have the filter, but this time I'm going to atleast make sure the IAT sensor is in the intake stream on my superduty. I will try to fabricate some type of heat shield, as the under hood readings for the IAT when it was zip tied to the brake res. were all over the map.
