squealing serpentine belt
Dave
Possible Source(s):
Drive belt.
Pulley(s).
Action(s) to take:
DETERMINE what area of the pulley(s) the noise is coming from, then CHECK that area with a straightedge and look for the accessory pulley(s) to be out of position in the fore or aft direction, or at an angle to the straightedge.
Possible Source(s):
Incorrect drive belt installed.
Action(s) to take:
CHECK the drive belt for correct part application.
Possible Source(s):
Lubricant or other contamination on the drive belt.
Action(s) to take:
CHECK the drive belt for oil, coolant, power steering fluid, brake fluid or other contamination. REMOVE the drive belt and wash with detergent and water. If the drive belt cannot be cleaned or is damaged (softened) by contamination, INSTALL a new drive belt.
Possible Source(s):
Drive belt pulleys not aligned properly, damaged or not rotating freely.
Action(s) to take:
CHECK the pulleys for proper alignment, devices and pulleys for proper freedom of rotation and damage. REPAIR the pulleys and devices as required.
Original equipment drive belts are made of a special cord construction and are subjected to special testing before they are approved for use.
Replacement drive belts, other than O.E.M., may track differently or improperly. If a replacement drive belt tracks improperly, the drive belt should be replaced with an O.E.M. drive belt to avoid performance failure or loss of drive belt during cold operation.
With the engine running, check drive belt tracking (the position of the drive belt on one of the grooveless pulleys, idlers or drive belt tensioner. If the edge of the drive belt rides beyond the edge of the pulley, noise and premature wear may result). If a drive belt tracking condition exists, visually check the drive belt tensioner for damage, especially the mounting pad surface. If the drive belt tensioner is not installed correctly with the locating pins in the locating holes, the mounting surface pad will be out of position. This will result in abnormal drive belt tension and chirp and squeal noises.
If the above procedures do not correct the drive belt noise, try replacing the drive belt with a known good original equipment drive belt. However, the drive belt noise may return (with mileage) if one of the above conditions still exists uncorrected.
With engine running, visually observe the grooves in the pulleys (not the pulley flanges) for excessive wobble. Install new components as required.
Check all accessories, mounting brackets and drive belt tensioner, for any interference that would prevent the component from mounting properly. Correct any interference condition and recheck belt tracking.
Tighten all accessories, mounting brackets and drive belt tensioner retaining hardware to specification. Recheck drive belt tracking.
Belt Tensioner
The automatic drive belt tensioner can be checked as follows:
1. With the engine running, observe the drive belt tensioner movement. The drive belt tensioner should move (respond) when the A/C clutch cycles or when the engine is accelerated rapidly. If the drive belt tensioner movement is constant without A/C clutch cycling or acceleration, a pulley or shaft is probably bent or a pulley is out of round. In rare cases, excessive drive belt rideout (uneven depth of grooves in drive belt) can cause excessive drive belt tensioner movement. This condition can be checked by replacing the suspect drive belt with a known good original equipment drive belt and repeating the observation.
I always use NAPA belts and have not had a problem that I can remember.
Russ
But guess what?...Yep the squeeling returned approx 3 months and 2000 miles later (May 31st)
-This time I took the belt off and cleaned all the pulleys with alcohol and a toothbrush, I also cleaned the Serpentine belt, I noticed that the top idler pulley had about a 1/32nd" play in it fore & aft. Reassembled everything and it seemed after the cleaning, everything got louder and worse! Loading up the accessory's amplified the squeeling! (Headlights on bright, Max AC,Radio,Cigarette lighter etc...)
So after the 3rd time of removing the belt I went out and purchased a new idler pulley, and a "Goodyear Gatorback poly V" belt " which boasts that they are the "Quiet Belt"...alot tighter in the new install vs. the motorcraft one with only 2000 miles on it. After a couple busted knuckles and a burnt fore arm, I fired-up the engine and she purred like a kitten! The NASCAR logo looks cool on the belt as well!--Good luck! just relaying my experience,a word to the wise-Spend the extra money and get a Goodyear Gatorback cross-hatched Serpentine belt!
How much and is it pressed or a formed one?
