Hello all, Have questions, I have been read about Ivan and some other doing the shackle flip. I have a stock 79 F 250 (except motor) with 33's on it. I dont have the good fortunes most of you do to go play in the mud because I live in the Arizona desert. I use my truck as a daily driver for work which has me off roading around 75% of the time. Now with that out of the way here are my questions.
1. Can you flip the shackle without any other lift kit?
2. If so How much lift will I get? (about)
3. Since I am in the desert and do mostly rough rocky hills and soft sand bottom areas. Is this a good idea.
My overall goal is a little more clearence for bigger tires and a smoother ride.
1: Yes, however this will only be lifting the rear, you'll have to find some way to lift the front (dont use blocks!)
2: I got about 3 1/2 inches on mine, so im ditching the stock lift blocks that came on my truck (73 highboy)
3: It could possibly allow your rear axle to articulate a little better off-road. It should smooth out the ride a bit.
Flipping the shackle is not a good idea if you plan to tow alot or carry heavy loads in the bed since these shackles wont support the lateral forces. You could try welding in a small flat plate on the open side of the shackle for extra strength however.
You will need longer shocks (The shocks you use will determine how smooth the ride will be. Gabriel LT's are nice for an empty bed). Make sure your brakeline and brake cables have plenty of slack. Because the leaf springs pivot on the front hanger, the axle may have been moved forward about 1/2 an inch, so watch tire-to-fender clearance. Also, make sure you get the right angles! I had to move mine exactly 4 inches forward to get a 90 degree angle on the shackle with no load on the springs, but I have the skyjacker 4 inch lift springs too.
Amtek - Its good to know how far forward to move the hanger, I'm flipping my shackle here shortly and adding a bit more lift to the front to account for the difference.
I carry about 800-1000 lbs, never weighed it but a full truck bed all surveying gear in my truck at all times, And on out of town jobs I tow a trailer with two quads 750 lbs each plus the trailer.
Now know that is this a good idea? Or what is the best way to get more clearence.
90 degrees is the last thing you want your shackle angle at. Worsens the ride a great deal. Should be closer to 45. I wouldn't do a shackle flip in a truck that carries 1000#. You COULD, but you'd better build it beefy.
if i were you and you weren't looking for anything more than bigger tires and being so dry out there i would seriously consider trimming the fenders. even get fender flares that would look gooooood!
Could you use a rear spring front hanger for a shackle flip? As long as the frame rail doesn't widen/narrow toward the rear it should work. This pic is of a Chevy, but it's the same concept.
Hmmm, I only found the same picture he linked; which the shackle straight up and down at 90 degrees. But I'll take your word for it Must be pretty soft springs for the bed to take them down that much...makes for a nice cushy ride.
