61 engine/tranny change?
Old May 27, 2005 | 12:02 PM
Churchman's Avatar
Churchman
Red face 61 engine/tranny change?
I have recently gotten a 61 ford unibody. It has an old mud covered, locked up six and no tranny. I have also been given a mid 80 (not sure exactly) model 302 with an early 90 model, Mercury Tranny bolted with it. The people who gave it to me said that the tranny used to shift fine but now with the older motor it does not have enough vacuum or vacuum hookups and will not shift correctly. A Few questions here:
1) Will this 302, with it's mounts, mount right up to the chassis or will I need to get a kit like J.C. Whitney sells?
2) Does this transmission with not enough vacuum/hookups seem viable and if so what is the best fix?
3) Will the tranny mount out of the mercury do in the PU?
I have changed out motors and transmissions before but never with different ones than originally came in one. Please HELP!!!
Old May 29, 2005 | 06:17 AM
jowilker's Avatar
jowilker
Hey Churchman, Welcome to FTE The best truck show on the net.
I am not familier with JCWs kit, but you will need to install a side mount kit to install the 302/5.0
I am gonna guess that you may have an AOD tranny and it was not properly installed.
Is this a carb or EFI engine?
With a little more info, I'm sure the guys here can help point you in the right direction.
John
sierraben
Apr 10, 2006 07:28 AM
Rodder41
Paint & Bodywork
Mar 29, 2006 03:23 PM
msmyth
Mar 11, 2006 10:42 PM
jrzoffroad
Oct 14, 2005 12:30 PM
JoeBlow
Exhaust Systems
Apr 16, 2004 07:37 PM
