GM V-10 maybe???
The likes of fuel injection, full alloy block, deep-skirt block casting with six-bolt mains, coil-near-plug ignition system, hydraulic roller lifters, reverse-flow cooling, coutless revisions to head design, availble in about 8 or 9 (I can't remember) different capacities.
About the only thing the same between the 2 engines is the 4.4 bore centers.
The death of the SBC IMHO was with the LT1.
The buick aluminium V8 (if memory serves me correctly) was first introduced in 1957, and ran in full scale production cars up until 2005.
Am curious is the SBC being installed in any production vehicle? or is it merely sold as a crate engine?
Do you know production numbers on them? as mentioned I am just curious.
I am not saying the SBC is not a good engine, it has been a great engine for GM, but there are other engines around the world that have stood the test of time equally as well, if not better.
I didn't know about the bore centers being the same, but on a side note the current 5.7 version uses a smaller bore and uses less head bolts than its predesessor(sp?). Again, absolutely no interchangeability between the two.
The current 8.1 is a direct relative of the OLD 454. The HP has actually been reduced recently..........getting more difficult to meet emissions I'm guessing.
Curious to see a link to the 380 Hp upgrade alluded to earlier in a different post.
Except the SSR has an alloy block, and the trucks is cast iron... But still the same figures would be achievable.
Whether it would be a good truck motor though would be interesting. I have driven a 2005 GTO, and the engine is very tractable, but in something that weighs twice as much pulling a 10000lb load, I am not so sure...
BTW, congrats on the 4000th post too!!!
Try having a lump of cast iron sitting up the front of a Corvette...
Danko, how many miles on your V10?
Is it fully run in yet?
Believe me.
If you check out the V10 forum, all of the guys said it has taken that long for it to be properly run in.
And once it is, by gee they move...
