289 AOD combo
Old May 26, 2005 | 02:12 PM
ryans428's Avatar
ryans428
289 AOD combo
I was thinking of putting the 289 AOD combo im my 72', i was wondering will all years and models of the AOD fit on a 289? What should I look for to tell it is an AOD tranny? Will i have to get my drive shaft cut, it had the 3 spd tranny as of right now? And will the speedo cable off the 3 spd work of the AOD? Thanks
-Ryan
Old May 27, 2005 | 08:16 PM
fordxxx's Avatar
fordxxx
Ryan, if you do a search on AOD you will come up with a whole bunch on info on this install. Also in "Articles/Info", at the top of the page, there is a "Ford transmission spotters guide" that should help.
Old May 28, 2005 | 10:19 AM
390fe's Avatar
390fe
There was a design change in the 289 blocks where the old five-bolt bellhousing was changed to the newer six bolt design. Up to August 1964, 289's were five-bolts. Engines after that were the six-bolt design that will bolt up to the current line of aod trannies. So if you've got an early five-bolt 289, you will have problems bolting it up to anything.
nolan62
15
Nov 27, 2016 01:47 PM
willthesaint
Mar 23, 2016 09:49 AM
Holehawgg
21
May 27, 2012 10:34 AM
ralphmb123
Jun 20, 2011 07:11 PM
BSmitty
Oct 24, 2004 05:40 PM
