C8VE heads - adjustable valvetrain
Old May 25, 2005 | 10:54 AM
tecjr's Avatar
tecjr
I need some help with converting a set of c8ve heads to an adjustable valvetrain. What would be the best way to do this? Would this be a simple stud and guidplate installation with hardened pushrods? Is any machining required? And what parts would i need to use?
Thanks....
Old May 25, 2005 | 11:09 AM
greenhighboy's Avatar
greenhighboy
The easiest way is to use a set of Crane Kool Nuts in place of the factory nuts. I have done this on two motors and it worked good. No other modifications are needed.
Old May 25, 2005 | 12:57 PM
tecjr's Avatar
tecjr
Can i use roller rockers with that setup or will i need to use guideplate also?
Old May 25, 2005 | 01:20 PM
greenhighboy
The Kool Nuts work with the stock rockers. To use roller rockers you will need guideplates and hardened pushrods. You should also take .230 off the stud boss. Alot of people don't think that it's neccesary to machine the stud boss,but I have always done it and haven't had any geometry problems. I watched a guy at the machine shop do it and it only took like 15 minutes per head.
If you do go this way be sure to check your pushrod length. I have always needed shorter pushrods.
Old May 26, 2005 | 12:25 AM
merc460's Avatar
merc460
The only other advice is buy your pushrods last. after you have checked the length with a length checker, that way you will be able to get the best rocker arm geometry
I did not do this and I ended up having to buy lash caps to bring my geometry into a acceptable range.
Old May 26, 2005 | 02:57 AM
bigsnag's Avatar
bigsnag
Ford Racing makes a set of adjustable roller rockers that fit on pedestal type heads. They are machined to fit down in the notch just like the regualr rockers and they do not need guideplates.
MychalCrowson
24
May 10, 2007 03:07 AM
78Buford
Aug 10, 2005 12:55 AM
ajstephan
1983 - 2012 Ranger & B-Series
Dec 17, 2003 11:53 AM
BigJake86
Mar 15, 2003 08:26 AM
chesid24
Nov 26, 2001 01:10 PM
