Miss at startup
Old Oct 2, 2005 | 06:46 PM
  #31
fastow's Avatar
fastow
Fixed Mass Air Flow Sensor Ever Heard Of This Causing Start Up Problems?
Old Oct 3, 2005 | 12:04 AM
  #32
amish_dan's Avatar
amish_dan
ok my curiosity is peaked. i have the same problem on my 99, 4.0. and i sure think i've got it as tuned as posible.
the thing that helps usualy is the fuel injector cleaner. ya know that stuff you dump in the tank. i havn't done it for a while and the sputtering is getting bad agian. i'm anxous to hear if you all come up with somthing more profound that this.
Old Oct 3, 2005 | 05:22 PM
  #33
greenngld's Avatar
greenngld
I still haven't completly solved the problem that started this thread, but I have found one thing. If I leave the key at "On" for ten seconds or so before starting, it does not miss. Why that bypasses the problem I don't know, but it works. If I jump in and just fire it up right away, I get the miss sometimes.
Old Oct 4, 2005 | 03:57 PM
  #34
MSRanger's Avatar
MSRanger
I have the same problem on my 2000 4.0 4x4 S/Cab with 96K miles.
No CEL, no problems driving, but when starting and still in the (short) driveway, it misses while idling, and while just starting to roll forward or backward.
Once there's any amount of throttle applied, it's fine.
Haven't changed the fuel filter yet, and have only changed plugs once, about 60K.
Have changed the IAC valve last year, due to failure to idle when cold.
Old Nov 18, 2008 | 12:15 PM
  #35
bobjones113's Avatar
bobjones113
I have a 2000 with the same miss at startup. I have changed to upper and lower intake gaskets, the IAC, plugs, wires, fuel filter, MAF sensor, and my fuel pressure is at 60. I am thinking about the injectors but I am tired of throwing parts at this problem. I also do not have a CEL so no codes to read. If anyone has any other ideas I would love to hear it.
Old Nov 18, 2008 | 01:48 PM
  #36
Rockledge's Avatar
Rockledge
I've read about slightly cracked heads or leaky headgaskets causing misfires on the 4.0L OHV. In these cases, the problems are not enough to cause overheating or any other overt symptoms, but instead just an occasional misfire.
You might consider having a used oil analysis done to determine whether any coolant is mixing in with the oil. Cheap and easy to do: Blackstone Laboratories - Gas Engines
Old Nov 18, 2008 | 08:16 PM
  #37
bobjones113
The interesting part is that the truck only runs rough for about 10-15 seconds and then the engine smooths out. I would think that a cracked or blown head gasket would take longer than that to seal up from building engine heat. Other than the rough starts fuel milage is ok and power is normal, if this problem were some serious engine wear or failure I would guess that I would see some performance issues. The truck has 102K on the original motor.
Old Nov 20, 2008 | 10:40 PM
  #38
B A dawg's Avatar
B A dawg
Originally Posted by greenngld
Hello,
I have a 2000 Ranger, V6, 4.0L, 4x4. 90,000 miles.
I am having a problem at startup, with a miss. It only lasts for a few seconds, then everything seems fine. It also only does it on a cold start, not when the engine is warm. Basically, it runs really rough for a couple seconds, the RPMs are low by a couple hundred, then it catches and runs fine. It does it 9 out of 10 times if it is cold. After it starts running normal, everything seems good on acceleration and higher speeds. If I give it any gas while it is running rough, it doesn't help, just starts bucking faster.
Last week I got a check engine light, and it came back as a miss in cylinder 4. There was no noticeable miss at the time, and it hasn't come back on since it was reset. I assume it is from the same problem.
I've been having this same exact probem with my 98 4.0.
Changed the plugs at 100K. At 125K, bad miss from #4. Changed plug, perfect.
Now about every 4-5K the miss reappears. Fixed like new with a new plug on #4.
Kinda driving me nuts. Checked EGR, IAC, coil pack, wire, harness, etc. Also, problems with these or any other problems (head, gasket, IM or gasket, injector, fuel pump, etc. would NOT be immediately fixed by merely changing the plug. Have been using Motorcraft stock plugs. Plus there are no other misfires on any other cylinders. And, #4 plug is not fouled and otherwise does not appear to have anything wrong with it when removed. Even the ohm resistance is very close to a new plug.
I'm stumped, no logic to this. If anyone has any ideas, I'm all ears.
Old Nov 20, 2008 | 10:54 PM
  #39
Rockledge's Avatar
Rockledge
That sounds a lot like the experience that I had with mine.
https://www.ford-trucks.com/forums/2...ke-gasket.html
As I noted above, a UOA is something that could help with the diagnosis.
Old Nov 20, 2008 | 11:21 PM
  #40
B A dawg's Avatar
B A dawg
It could...anything's a possibility at this point.
Oil looks good, pretty clean even after 3K. No oil/ coolant mixing anywhere.
But, maybe I will try the analysis. What the hell, can't think of anything else to try.
But still, if it's a bad head/ gasket, a plug shouldn't do a damn thing, and the problem wouldn't go away and then return on a somewhat similar interval, know what I mean?
The problem almost seemed to me like this: a new plug had a lower resistance and as it aged, it developed a higher resistance until the ign system couldn't overcome the resistance anymore, leading to misfires. Kinda like the slow cranking with a good battery and old starter with higher internal resistance due to age or manifold heat problem/ scenario.
I dunno.
Old Nov 20, 2008 | 11:25 PM
  #41
B A dawg's Avatar
B A dawg
Rockledge-
Great post on the IM R&R, BTW.
Old Nov 21, 2008 | 12:23 AM
  #42
pawpaw's Avatar
pawpaw
I noticed you said you replaced the plugs at 100k miles, but did/have you replaced the plug wires????
Old Nov 21, 2008 | 08:51 AM
  #43
Rockledge's Avatar
Rockledge
I understand what you are saying. But in my case, I would change out the #4 plug and things would be fine for a while, and then a month or so later the rogue misfire would return. I went through 3-4 plugs doing that. And they all looked good when I pulled them, too. No signs of any problems. Which is why it was so difficult for me to nail down the cause of the problem. I did multiple fuel pressure checks, compression tests, cooling system pressure tests, etc. Then I had a UOA done and that pointed me in the right direction.
Check it out: Ranger Used Oil Analysis
Old Nov 21, 2008 | 09:05 PM
  #44
B A dawg's Avatar
B A dawg
Pawpaw- Yes, wires changed at 100K also.
Even tried a wire swap to rule out a bad wire, didn't help.
Rockledge- Well, I guess I'll try the analysis. From a purely logical point of view, I can't understand it, but if you experienced the same issue and found it thru analysis, then it certainly can't hurt to try one.
I'll get to it at some point and let you know what the results are.
Thanks for your time and all your posts to this site, you have an impressive knowledge base for the Rangers.
Old Nov 22, 2008 | 08:36 AM
  #45
03 Maz B23's Avatar
03 Maz B23
My 03 Duratech 2.3 has the same roughess when first started up cold that dissapears when warmed up. Makes me wonder if my engine has the same issues as those listed in these posts.
