General Automotive Discussion
94 taurus
Old May 23, 2005 | 07:34 PM
breez's Avatar
breez
94 taurus
I have no taillights but everything else works.Its not bulbs so could it be a switch?Dont know where to look. Need help
Old May 23, 2005 | 08:10 PM
tdister's Avatar
tdister
Do you have brakelights? if not, does your third brake light work? reverse lights? absolutely no lights on the back?
Old May 23, 2005 | 08:32 PM
breez's Avatar
breez
Old May 23, 2005 | 08:33 PM
e1p1's Avatar
e1p1
If it's a wagon look to see if the wire for the 3rd brake light on thte tailgate is pinched. Happened on my old '90 and messed up the turn signals.
Old May 23, 2005 | 08:37 PM
breez's Avatar
breez
not a wagon. I back fed it from the loom under the driver side carpet and they lit. So im stuck
Old May 25, 2005 | 09:10 AM
Rockledge's Avatar
Rockledge
Did you check the fuses? Looks like #15 (10A) in the instrument panel fuse box is the exterior lamp circuit fuse. A Brown (BR) wire runs from that fuse to a splice that feeds power to the both sides of the rear lamps.
Old May 25, 2005 | 11:48 AM
e1p1's Avatar
e1p1
Have you checked the headlight/tailight switch? Maybe the tailight portion went blooeey. I think I remember that happening to me on another car. Ah yes, 'twas my '71 VW bus.
