1976 E350 ford wiring problems
Old May 22, 2005 | 08:22 PM
steppentex's Avatar
steppentex
Red face 1976 E350 ford wiring problems
we have a 1976 Ford E 350 27 ft minimotor home with a 460 eng. it has a new alternator, and a new starter. old alternator locked up and shorted out the old wiring harness. am in need of wiring diagram for alternator, voltage regulator, and cyliniod, also any information would be helpful. i have the 4 wire round plug and 2 wire oval , rather than the 3 pin flat and 2 pin flat plugs. have changed the voltage regulator, cyliniod, and revamped an old wiring harness for the standard ford alternator setup, but it still smokes the wires just below the cyliniod. thanks in advance,,,,,,
Old May 22, 2005 | 09:30 PM
IceWagon's Avatar
IceWagon
Sounds like you might still have a short circuit in the vehicle. If you disconnect the wire that keeps smoking will the vehicle still run? Do you know what circuits that are lost if you disconnect the wire below the solenoid. If you can disconnect that wire and the vehicle still runs charges then you have a short in the vehicle.
Disconnect the battery, then disconnect all the accessory wires from the positive side of the solenoid and test them for grounds one at a time. Try it with the key off/ key on/ turn on/off lamps etc. Note the resistance of the wires to ground. When everything is off you should have O ohms of resistance. Even with stuff on there should be several ohms of resistance.
Old May 23, 2005 | 07:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome steppentex, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 23, 2005 | 08:16 PM
steppentex's Avatar
steppentex
ICEWAGON, thanks . will try the ohm meter. Steppentex
augustjames
Electrical Systems/Wiring
Apr 7, 2014 06:46 PM
jeff14346
Dec 27, 2011 05:17 PM
KWittmer
Dec 5, 2010 01:25 PM
josh390
18
Nov 8, 2008 04:03 PM
diehard_ford man
Jan 29, 2006 06:58 PM
