3G help
Old Dec 27, 2011 | 04:10 PM
jeff14346's Avatar
jeff14346
3G help
new alternator is installed, removed oem wiring from solenoid to front radiator support, removed voltage regulator. How much of original harness do I need to reuse? wiring harness has the horn wire to power it. unplugged 3 pin and 2 pin harness under solenoid area which is part of alternator harness.
I wanted to bump motor over with ignition switch, got nothing, prior to removal of harness, motor would turn over with switch
any help, advise, suggestions will be great
thanks
Old Dec 27, 2011 | 04:27 PM
Poison Oil Racing's Avatar
Poison Oil Racing
you need the complete horn relay harness for starters.
Old Dec 27, 2011 | 04:47 PM
HIO Silver's Avatar
HIO Silver
Try this:
Old Dec 27, 2011 | 05:17 PM
Poison Oil Racing
have you followed this thread at all:
https://www.ford-trucks.com/forums/9...g-upgrade.html
blick
Nov 10, 2014 01:50 PM
Queueball
Feb 15, 2013 08:53 PM
F250GH
Dec 25, 2008 03:30 PM
fords_forlife
26
Jun 25, 2006 03:55 PM
GeneStoner
May 21, 2005 05:32 PM
