keypad default code location?
Old May 25, 2005 | 12:00 AM
Ruckus's Avatar
Ruckus
Fellows, I think Bigles has the best idea.I hope it as easy to reset as disengaging the seat belt chimes.You could use a birthday, anniversary or part soc.sec. number etc.I did not know this was possible.Now to only git-r-dun.Thank You!
Old Aug 4, 2005 | 12:38 PM
BCrooks's Avatar
BCrooks
Originally Posted by powerglide
The code is on a black module behind the back seat on the cab wall. Just completed this seat removal crisis and was glad its over. Simple though , just cram a 1x4 between the bottom bar and the seat bar. Push back and jack up at the same time.Remove the nuts in the middle belt box first though.
Is this technique for removing the back seat back for the extended cap or the supercrew (or both)?
Old Aug 4, 2005 | 02:43 PM
BCrooks's Avatar
BCrooks
I just confirmed. This modules is behind the rear seat of my 2004 FX4 SC. The number is very clear and work with the remote keyless entry on my door.
Old Aug 4, 2005 | 03:01 PM
78moneypit's Avatar
78moneypit
removing the seat - bolts in the belt box?
Somebody mentioned removing some bolts in the center seatbelt box. Maybe this will be obvious if I remove the trim, but are you talking removing the entire upper, center seatbelt retractor? Or are there some seat bolts that are concealed by the retractor's trim?
mbunney
Dec 30, 2017 06:47 PM
chrowen
2004 - 2008 F150
Oct 9, 2010 02:25 PM
Doovehead
2004 - 2008 F150
Dec 18, 2008 07:41 PM
scooterman320
2004 - 2008 F150
Feb 6, 2006 11:05 PM
BgBckHntr
Feb 8, 2004 01:46 PM
