wierd problems '01 f350
Old May 19, 2005 | 11:10 PM
mattmonson's Avatar
mattmonson
driving or not every now and then it cuts out like its out of gas, if my rpms are high it wont die but anything below 1and a half thousand it dies. stop and restart and everythings fine. just changed the fuel filter happens about 10-15 times a day now, becoming a problem. any help will be great, thanks.
Old May 19, 2005 | 11:40 PM
Bigsilver95's Avatar
Bigsilver95
Cam position sensor would be my guess, about 160 from ford, about half that from international, easy to change, sensor on from of motor, by water pump, 2 10MM Bolts hold it on.
Old May 20, 2005 | 12:17 AM
mikey123's Avatar
mikey123
mine was doing the exact same thing
if it was idleing it was as if i turned the key off
when driving it would die but not stall
took it to ford and they changed out the cps in about 10 minutes and i was on my way
cant tell ya how much it was warranty paid for it
Old May 20, 2005 | 10:46 AM
baalex's Avatar
baalex
I got a 01 f350 that did the same thing. Cam sensor was the problem, they said. 3 weeks later it did the same thing again. Turns out there was a spot in the wireing that had rubbed through. Replaced wire harnes and cam sensor, now it run great
Old May 20, 2005 | 10:59 AM
Bigsilver95
generally this will be a cam sensor issue, wiring and such are usually fluke things
ADavis7.3idi
Feb 6, 2017 07:39 AM
Neett
Jan 2, 2016 05:08 PM
Jrupe
Nov 15, 2015 03:27 PM
kedlin88
Dec 25, 2011 07:14 PM
lite2fan
May 5, 2004 09:07 PM
