Crankshaft Storage
Old May 18, 2005 | 09:39 PM
Weevil's Avatar
Weevil
Question Crankshaft Storage
I have a good crankshaft I just removed from a engine and wonder how to best protect it from rust. I will probably use it sometime in the future but it may be a couple years or more. Would just greasing up the journals work? Any kind of grease? Should it be covered or placed in a big plastice bag?
Thanks
Old May 18, 2005 | 09:51 PM
rainbowATF's Avatar
rainbowATF
Spray with white lithium grease or coat liberally with bearing or chassis greases; wrap in cloth and keep up off floor (dry place). Plastic not good; it will trap water condensation during seasonal temp changes.
Old May 18, 2005 | 10:20 PM
rusty70f100's Avatar
rusty70f100
I like to use marine wheel bearing grease. It's got the most water and rust resistance. If you're really paranoid you can use a grease gun and fill the oil passages with grease. Stand it up on end to prevent bending. I like to stand it up on some greasy cardboard. Then, place a bag on top of it to keep the dust off. Leave the bottom of the bag open. Should be ready to sit.
Old Jul 14, 2005 | 07:45 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
ive always heard to store a crank on end to keep it from bending. how exactly will it bend when its laying on its side? its being suported more or less evenly by lots ofcounterweights if u set it right. i can see maybe if it was on concete and not sittin right and the middle counterweight is the one holding up 1 side- but if its on cardboard on a wooden shelf layin down suported as evenly as it will lay down how will it bend? im not sayin set it down on the concrete floor just evenly support it.
Old Jul 14, 2005 | 08:28 PM
Weevil's Avatar
Weevil
Thanks
Yes, thanks, that makes sense. I too have always been told to store them on end but if one would set them down carefully and well supported should be just as good.
Old Jul 14, 2005 | 09:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
FWIW- They were always stored on end at the crankshaft grinding company I worked for. We ground crankshafts up to 10 feet long.
Old Jul 15, 2005 | 01:23 AM
ford390gashog's Avatar
ford390gashog
cranks always need to be stored straight up.
Old Jul 20, 2005 | 11:34 AM
94F150-408's Avatar
94F150-408
humm, the storage on end is an interesting one. I never really thought about it. It seems a shop would store them that way because they would take up less shelf space, but bending because they are layed down? Does anyone know if this is a fact or just an urban legend ?
Old Jul 20, 2005 | 06:02 PM
Weevil's Avatar
Weevil
Good question. They sure don't bend when being supported in the engine by the main bearings. Probably safer from damage and take less space on end. Not so easy for them to be damaged by carelessness. Probably difficult and time consuming to support them the way they are in the engine.
Old Jul 20, 2005 | 06:10 PM
94F150-408's Avatar
94F150-408
I would guess we are correct on the reasons for storing them in this manner weevil, I just have sincere doubts that they are going to "bend" from just sitting there. If anyone can further enlighten the group on this, it would be of interest to many.
Old Jul 20, 2005 | 07:14 PM
EPNCSU2006's Avatar
EPNCSU2006
When the crank is in the engine, the main bearings support the crank along the centerline of the crank. When you lay a crank on its side on the floor, it is being supported by the counterweights, which don't act on the centerline of the crank. That's how I understand it, at least.
Old Jul 20, 2005 | 10:06 PM
mblayton's Avatar
mblayton
Cranks should always be stored on end because of being able to bend, the only way to store laying down is if it were supported the way they are shipped to performance shops and that is in styrofoam which is cut out to match counterweights and journals
Old Jul 21, 2005 | 02:07 PM
noFordguy's Avatar
noFordguy
i dont know about you guys but i allways have taken the time to make a stand out of wood. suport the crank by all the main journals. this way you dont have to worry about it falling.
Old Jul 29, 2005 | 05:20 PM
MEANBLUOVL's Avatar
MEANBLUOVL
It dosent bend it warps because of the gravity pulling down on it.
Old Jul 29, 2005 | 08:02 PM
Weevil's Avatar
Weevil
Exclamation
A warped or bent crankshaft makes for a rough running engine.
