Axle U-Joint question
Truck: '89 F250 Supercab, 460,c6,4x4,manual hubs,167k.
Question: I am going to repack hubs soon and replace the rotors at the same time. Whats the skinny on replacing the front axle U-Joints do I do it just because I am so close or do I wait till it's needed, and how do I tell if it's needed? No play or loosness is evident when shaking and tugging the axle while it's installed. Only reason I ask is EVERY other U-Joint in the truck has been replace at least once and the carrier bearing too
Front end is seldom used anymore and hasn't been for last 10 years. Before that is was just used on snowy highways, total off highway time on truck is probably less that 500 miles and 90% of that was on passenger car type dirt roads
Thanks
IMO, I'd replace them. The only extra thing you'd have to do to get the axle shafts out is take the spindle off. You take those little nuts off, and there are two ways I've seen to pull it out.
Use a slide hammer with a socket attachment that will screw onto the threads at the end of the spindle (best way).
Use metal chisels and hammer away around the edges of the spindle. It'll take a little while to see progress, but it'll work, I've done it like 10 times.
Once the spindle is out you can slide the shaft out and replace the u-joints in them. There are three, and the passanger side axle shaft is a 2 piece unit that comes apart in the middle of it.
IMO, you can't tell a front u-joints condition with it in the truck, all these tests that were posted, can give you an idea...but you really don't know unless you pull it out and feel it by hand. You want to move it in all directions looking for binding, roughness, or even looseness. If they've been in there for awhile, chances are they should be replaced. They're not an expensive part, just time consuming to replace.
My buddy had an 89 wrangler that lost a front u-joint while driving on the highway, I think it was on the front driveshaft though...it ended up breaking the knuckle on his front axle, the front axle shaft on that side, cut fuel lines, broke the bellhousing on the transmission, yada yada yada....lots of damage.
