Tilt Bed ??
Old May 18, 2005 | 01:23 AM
superman64011's Avatar
superman64011
Tilt Bed ??
Down at the Supernats and saw some Tilt Beds....How many of you have tilt beds and do they sell a kit or did you fab yourself??...If so how hard to install or Fab? If fabbed yourself please give some detail....Just thinking about ideas. Not really sure I am gonna do it....
Thanks
Patrick
Old May 18, 2005 | 09:13 AM
fatfenders56's Avatar
fatfenders56
did a tilt bed a few trucks back, used the rear pivot assembly from a front axle. Punch 3 rivets out and the whole thing comes out as a unit. I have some pictures but they are old and I'll see if I can scan them in and get them into my gallery. Check pickupslimited.com for a couple of good pics from K'ville
Old May 19, 2005 | 10:17 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Fatfenders, I can't quite picture what you're talking about( I think the rectal cranial inversion is acting up today)
I know there are several manufacturers of bolt on tilt units. A web search should turn up several. I've seen them listed in the Northern Tools catalog. You might try talking to one of your local hydraulic shops or truck equipment company.
Good luck
Bobby
Old May 19, 2005 | 03:12 PM
fatfenders56
Let me see if I can 'splain it more better. What I used is the rear hanger/pivot assembly from an I-beam front axle. It's where the rear of the spring attaches to the frame. Drill out the 3 rivets and you will have a real nicely made pivoting assembly that the spring used to hook to. Use a pair of these to mount the rear of the bed to the frame and you will have a tilt assembly with a grease fitting and you will never wear it out! I used a hydraulic ram from a small dump trailer to raise it up and down. Hope that's clearer!
Old May 19, 2005 | 03:27 PM
bobbytnm's Avatar
bobbytnm
Fenders,
Doh! I got it now. What a great idea! And to top it off the bracketry would look period correct.
Was the cylinder manually operated, pump mounted on engine, or electric?
Thanks for the clarification
Bobby
Old May 19, 2005 | 04:55 PM
fatfenders56
12v electric powered the pump
Old May 19, 2005 | 05:12 PM
bobbytnm's Avatar
bobbytnm
Fantastic, thanks for the info
rwrogers
Feb 15, 2014 12:21 PM
70-360fe
Jan 15, 2013 05:09 AM
bigfoot7180
Oct 17, 2012 09:34 PM
superman64011
May 16, 2011 11:22 AM
RE_SPEED_FAB
Mar 27, 2002 01:52 PM
