head lights problem
Old May 17, 2005 | 11:45 PM
spankin460's Avatar
spankin460
head lights problem
i have a 79 250 supercab ,when driving at night my head lights start to flash on there own for a few flashes then go out .the parking lights stay on .if you turn the headlight switch off then on ,they seem fine for maybe 30 min or so .could this be a ground issue?
Old May 18, 2005 | 01:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
The most common problem is the headlight switch with the built in circuit breaker. The other problem is the dimmer switch and then sometimes a bad ground.
Old May 18, 2005 | 02:13 AM
83sd's Avatar
83sd
i too am battling this issue,along with others. my turnsignals blow the fuse right when you try to drive off,i had to rewire the dome light because theres a short somewhere that i cant find. anyone know where i can buy a new cab wiring harness? maybe an engine harness to?
Old May 18, 2005 | 02:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is a tech article here on turn signal diagnosis. You can buy wiring harnesses from Jeff's Bronco Graveyard: http://www.broncograveyard.com/
Old May 18, 2005 | 09:51 PM
willydad's Avatar
willydad
answer to headlites off/on
i had same problem with both 74's. contact www.madelectrical.com for relay kits--one for brights and one for dims. you can replace switches all day long but until you fix problem, symptoms will return. with relays, lights are brighter now and i could upgrade to "silverstar" lamps if i wanted. by the way, part number is RLY-1. need 2. a few hours and about $70 ??? and you'll be a happy trucker again. i am.
Old May 18, 2005 | 10:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is also a tech article here on the relay conversion setup. If the floor dimmer switch is bad it will need to be replaced anyway.
Check here:
https://www.ford-trucks.com/article/idx/8/0/
armstrongfordtrucks
Feb 11, 2011 08:33 AM
yoeman
Nov 11, 2006 11:42 AM
underDAWG
22
Jun 24, 2006 10:46 PM
EPDP99
Sep 28, 2005 05:17 PM
MarkP
Aerostar
Apr 17, 2001 11:30 AM
