E4od to C6?
Old May 17, 2005 | 08:39 PM
Scott Fraser's Avatar
Scott Fraser
E4od to C6?
Rather than rebuild my E4od, would it be more cost effective to replace it with a rebuilt C6? Are the bolt patterns from a 7.5 gas to a 7.3 diesel different? Thanks.
Old May 17, 2005 | 09:14 PM
farmnfly's Avatar
farmnfly
I'm not sure about the bolt pattern, but I know the torque converter for the diesel has a slower stall speed and you'll have to your drive shaft shortened, also the c-6 has a mechanical kick down linkage, the e-40 does it electronically. Although if you could get a c-6 from an older pre e-40 diesel you can get everything you need. Just a comment, I have an 84' 6.9L c-6 that gets 12 MPG, and I have a 92' 7.3L e-40 that gets 16 MPG.
Old May 17, 2005 | 09:21 PM
Scott Fraser
I as well get 16mpg with the E4od and it doesn't impress me that much.
Old May 17, 2005 | 11:29 PM
Spectramac's Avatar
Spectramac
With the diesel prices the way they are, I'd stick with the OD (even though it's a piece of crap).
Old May 18, 2005 | 05:08 AM
trike1946's Avatar
trike1946
I have a 90 E4OD. It was rebuilt in Dec. It runs great now. I had the heaviest valve body put it when they did it. There is a light, medium and heavy. It slams right into gear, no slipping. My truck loaded weighs about 9k and I am towing a trailer that is about 6k. Make sure you have a big cooler in it. I am using synthetic fluid. There are also companies that make heavy duty torque converters. Banks has one but it is costly.
Bill Mole
Engine Swaps
Jul 22, 2007 09:54 PM
knapikmichael
Dec 13, 2006 06:50 AM
snotwilim
Sep 11, 2006 12:06 AM
mustangandy
Sep 26, 2005 09:32 PM
jeepnford
Oct 27, 2000 09:18 PM
