Neutral safety switch
Old May 17, 2005 | 10:20 AM
Todd K's Avatar
Todd K
hey guys i have not even tried to figure this one out yet i figured it would be better to ask you guys before i "F" something up. my netural safety switch will sometimes not allow me to start in park (66 with 352 and c-6 auto.) what do i need to do so i don't have to jiggle the handle, or put it in "N" to start.
Old May 17, 2005 | 11:15 AM
William's Avatar
William
Check to see if the switch is tight. Check to see if the column bearings are good (especially the bottom one). Adjust the switch by loosening the retaining screws and sliding it.
Old May 17, 2005 | 11:29 AM
Todd K's Avatar
Todd K
thanks, one of these days i'll check it out. i've been putting it off for quite some time. Lately I automaticly put it in "N" with out even thinking about it. Today it's at the shop for a state inspection, the mechanic had a battery charger on for two hours, and tried to start it again and still wouln't crank. thank god he called me instead of pulling the starter or something. Anyway sounds like an easy enough fix. It's probably loose, every other screw in the truck has been loose so far.
FUJINAMI1293
Jan 12, 2017 07:10 AM
econolow
Aug 28, 2008 08:26 PM
MTrumpy
Jul 19, 2007 08:08 PM
BlueOvalDrifter88
1978 - 1996 Big Bronco
Dec 4, 2005 01:05 AM
cajunsf
Electrical Systems/Wiring
Jun 18, 2004 02:22 PM
