Motor for Off-Road
Old May 16, 2005 | 10:31 PM
fordbubba8206's Avatar
fordbubba8206
i got a 352 in my 66. it hasnt run for quite a few years and i plan on turning the truck into a huge off-road rig with 46. should i push the engine to the limit or what size motor should i use?
Old May 16, 2005 | 10:33 PM
rusty70f100's Avatar
rusty70f100
Your best bet would be to start your own thread with more detail. I'll answer your question there.
fordbubba8206
46 " tires, should i use a 460 and beef it up?
Old May 16, 2005 | 10:35 PM
fordbubba8206
what kind of detail do u want?
Old May 16, 2005 | 10:44 PM
rusty70f100
Oh where to start!
1. How much money do you want to spend?
2. Do you want to burn pump gas?
3. Are you doing any sort of competition, which would have rules to limit anything?
4. Are you concerned with street drivability?
5. What kind of transmission are you running?
Basically it goes like this: Good, fast, cheap. Pick any two.
The more detail you give on what you want, the better my recommendation will be.
Old May 16, 2005 | 10:50 PM
fordbubba8206
as much as it takes
yes
off-road challenge
yes
will be Dodge 5-speed
i want it to be reliable
and a crowd pleaser
Old May 16, 2005 | 10:52 PM
rusty70f100
Ok go back to the FE board and start a new topic. We've already intruded on Skinsey's thread too much.
Old May 16, 2005 | 11:11 PM
fordbubba8206
im more comfortable doing it right here
Old May 16, 2005 | 11:16 PM
rusty70f100
Ok fine, but the moderators might frown upon it. More users will look at your question if it's listed in the topic list.
Now that we've established that there are rules to contend with, what are they, in relation to the engine?
It seems you've chose "good" and "fast". Very well.
Just as soon as you tell me what the engine rules are, I'll get on recommending a build. The FE will work great, no need to change out to a 460. It'll just make you sink/roll/fall off faster.
Old May 16, 2005 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
New thread started.
Old May 17, 2005 | 10:32 AM
Mike G's Avatar
Mike G
I'll bite...
Take the 352 and have it bored +.050. Drop in a 428 crank with the low compression 390 pistons and build a 410, with a 941 crane cam and adjustable valvetrain. I think you may need a few $$$ adapter to get the tranny hooked up, if possible. Set of gears around the 4.56 or 5.11 range and you should be set. Also set aside around $3000 for the motor and $3000 for the other items, that should get you in the dirt
--Mike
Old May 17, 2005 | 03:06 PM
71 Muddbugg's Avatar
71 Muddbugg
On ebay there is a dual 4 intake for the fe and someone else has a set of 5.56 gears!!
Buy those and about 15" of lift along with Mike's suggestions and you'll have some thing to please the crowds!! Wheelies, endo's, snapped u-joints, mud in the intake....oh the fun!
Old May 17, 2005 | 04:40 PM
mswift's Avatar
mswift
HA! Aint that the damn truth. Do yerself a favor and swap all U-joints to the same size. That way you just carry a couple of the same size in your glovebox with your 1/2" wrench.
And once you get good at snappin' em, you can walk into your local NAPA and they'll have a couple waiting for you.
