Ecm...
Old May 16, 2005 | 09:45 PM
Stang5lgt's Avatar
Stang5lgt
Ecm...
I put a 2000 7.3 in my early 99. The truck runs great when I get up to highway speed. No power below 60. I am guessing the Injector module from my early 99 isn't set up for 2000 injectors. I was wondering if anyone knows if the computer can be swaped for 2000 up computer? They look the same size from the pics I have seen. And I know they go in the same place. But I can't tell if the plug is the same. Thanks to anyone who can help.
Old May 17, 2005 | 07:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The IDM (injector driver module) is virtually identical in all year powerstrokes. They will all interchange without affecting anything. If you meant the PCM (powertrain control module) then there may be a compatibility issue between the early 99 and 00. The plugs are identical, and will swap without issue. IF the early 99 and the 00 both use AD code split shot injectors (the 00 does) then changing the PCM won't do anything either.
Old Jun 4, 2005 | 08:58 AM
normn7337's Avatar
normn7337
Virtually Identical?
I'm having a problem with my IDM. It shut down just like you turned the ignition switch off on the highway. Had it towed to a dealership. Hoping it was just the CPS. I was wrong. The dealership quoted me $1400 to replace the IDM. I talked to the technician and he gave me the codes (p1292 and p1293) and towed it home. I pinpointed the IDM using the service manual, both codes led to IDM failure. I removed the IDM from my early 99 F250 (By the way the dealership wanted $300 labor for this, I am definitely in the wrong business).
I was able to purchase a used IDM off of a parted/totaled out 2002 (the engine ran). My original IDM has an aluminum backing, the newer one has a black backing. Will these swap with no problem? My biggest fear is plugging it in and frying something downstream. I have a relative at a distant dealership that can get me the correct IDM at cost. However, I can buy several used operational IDM for the cost of a new one. I also figure these are not a wear item. They either work or not (electronic, as long as you keep them dry, but really I dont know how you would get them wet in an OFFROAD 4X4 vehicle ).
Old Jun 4, 2005 | 11:22 AM
444dieselrod's Avatar
444dieselrod
$1400!!!!! wow!!!!! you can gat them used for like $200, and they take 15 minutes to swap out.
its a direct bolt in swap, you should have no problems, like cookie said there all interchangable.
Diesel Rod
Old Jun 4, 2005 | 03:56 PM
touchofgrey's Avatar
touchofgrey
Diesel Rod
Must be a slow month. LOL
Stealership is certainly the correct term for that fine establishment.
mechelement
13
Jul 19, 2014 06:41 PM
towsrus
Oct 28, 2011 11:34 AM
ggirten
20
Oct 14, 2010 11:43 PM
bigtoyfreak
Jul 25, 2006 09:28 PM
Stang5lgt
Jan 29, 2006 02:36 PM
