Are there performance chips for 95 150's?
Old May 16, 2005 | 04:50 PM
OregonTom's Avatar
OregonTom
I have a 95 150 Eddie Bauer 4x4 with a 5.8 litre. I did the K&N intake and flow thru cat back and that really helped. Are there any tuner chips made for this or tuner devices for tweaking setting in feul map or tranny? Thanks.
Old May 16, 2005 | 04:55 PM
95 F150's Avatar
95 F150
Yes, they make what is called a twEECer for tapping into the ECU using a laptop computer. Figuring how to use it takes a long time from what I've heard and I'd be a little worried about messing up my engine from an improper tune. It would be nice to have control over the computer though.
Old May 16, 2005 | 04:57 PM
OregonTom's Avatar
OregonTom
No hand held units
Is it because this model is pre OBDII? Or is it OBDII. Thanks.
Old May 16, 2005 | 05:16 PM
Pantera-nm's Avatar
Pantera-nm
1996 and newer vehicles are OBDII (with a few exceptions). I have a 1995 F150 and I know it is not OBDII.
Old May 17, 2005 | 04:46 AM
95 F150's Avatar
95 F150
It's because on a OBD1 setup like a 95 model there is no tuner available so the the tweecer is the only thing you can do to be able to tune your own vehicle. On 96+ f150's that are OBD2 you can get tuners from all of the big chip manufacturers that are alot easier to use than the tweecer.
Automator
Computer Chips & Tuners
Jan 17, 2010 05:54 AM
trev1981
May 4, 2008 01:21 PM
david00f150
3.8 & 4.2L V6
Dec 9, 2006 07:32 PM
GSDogs
Mar 23, 2006 10:37 PM
michaelgoering
1997 - 2003 F150
Jan 4, 2004 07:03 PM
