Sponsored by: Kumho
hard steering
Old May 15, 2005 | 07:59 PM
stevesbigbad4x4's Avatar
stevesbigbad4x4
hard steering
I am experiencing hard steering on my 2002 f350. The powersteering works fine when it is moving but when it is sitting still it seems like it has no power to turn the wheel. Any Ideas would be appreciated.
Old May 16, 2005 | 04:18 PM
peppermrj's Avatar
peppermrj
Check the belt and tensioner?
Old Sep 5, 2005 | 05:40 PM
jwc9's Avatar
jwc9
I have been searching and seen this. I have the same problem. The steering is fine unless I am sitting still and then it is hard to turn. NO NOt a belt or pulley problem. Has anyone had this and corrected it?
Old Sep 5, 2005 | 06:25 PM
honkeyboss's Avatar
honkeyboss
My 93 F-150 was the same way. It was just that the tie rod ends and ball loints were bone dry. I lubed them up and it was fine for a few weeks, then it came back. I finally replaced all the tierods and everything is fine. Also, probably from the extra load on the steering, the gearbox itself had to be tightened up a bit. Now, its like driving a new truck.
Old Sep 5, 2005 | 07:13 PM
jwc9's Avatar
jwc9
all That is ok too. It is like the power steering just quits pumping when sitting still.
Old Sep 5, 2005 | 07:26 PM
peppermrj's Avatar
peppermrj
Cheap as I am I would try a flush and fill first. Harold at the Power Brake X-change knows all and tells all. (800) 580-5729 A small family outfit in Pgh. Pa., They are a factory authorized rebuilder and parts distributor. Every time I go there a dealers truck is picking up or dropping off and I'm there almost every day(his leterrcarrier). Give him a try mon -fri till 4:30
Mike Stuckey
Nov 17, 2016 11:12 AM
Scott Yager
May 8, 2016 09:02 PM
Medicman78
Apr 10, 2014 08:39 AM
landdesigns
2004 - 2008 F150
Jul 24, 2010 04:22 PM
