Sponsored by: Real Truck
Brakes
Old Apr 9, 2014 | 10:27 PM
Medicman78's Avatar
Medicman78
Brakes
Can get up to speed about 55-60 in my 2003 f250 6.0 4x4 truck and hit the brakes hard and the pedal gets hard almost like you cut the truck off and the truck doesn't stop well I can let off the pedal and hit it again hard and it works like it should. Also when it does this the power steering doesn't work. I was on an exit ramp and almost wrecked when I exited off the interstate I hit the brake pretty hard and couldn't steer I let off the brakes then hit them again and it worked fine and so did my steering. It would seem that the two are connected somehow. Any ideas what's wrong?
Old Apr 10, 2014 | 04:54 AM
redford's Avatar
redford
FTE Leadership Emeritus
The brakes and steering are both powered by the power steering pump. Start with checking your power steering fluid and your serpentine belt.
Old Apr 10, 2014 | 08:39 AM
Medicman78's Avatar
Medicman78
I'll check that. I recently had a new belt put on it may be a few months old Thanks for the reply.
Obs7.3Powerstroker
13
Apr 15, 2019 10:28 PM
Helmut Ree Darbouze
Feb 18, 2018 08:06 AM
bcaughhorn
May 31, 2014 03:25 PM
paulford
Aug 9, 2006 01:01 AM
mudcat12
Feb 27, 2004 05:30 AM
