1995 PSD no speedo, no cruise blowing fuse
Old 05-14-2005, 08:47 PM
Bob 79 supercab's Avatar
Bob 79 supercab
Bob 79 supercab is offline
I have a 1995 PSD with a 5spd. Today all of a sudden the speedo quit. Of course now the cruise does not work either. I checked the fuse for the speedo and it was blown.
Now if I replace the fuse it just blows again right away. All other gauges work as they should.
I'm leaving for a 1500 mile trip and I'd like to know what the problem is.
Can anybody help me.
Bob
Old 05-14-2005, 09:43 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Look around in the steering column for frayed wires grounding out.
Old 05-15-2005, 12:14 AM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Got a question for ya Bob.
That '79 supercab doesn't happen to have a 5.9 cummins in it, does it???
Diesel Rod
Old 05-15-2005, 02:24 AM
Bob 79 supercab
Diesel Rod, I wish the super cab had a diesel but I do like the 460/
Old 05-15-2005, 11:26 AM
444dieselrod
OK, thanks BOB
I met a guy a few weeks ago at a dyno day and he had a '79 supercab and it had a 5.9 cummins and the 5 speed behind it, just thought maybe you were him.
For your problem I would go with what kwik said, start digging into the wires under the dash on the column, prolly a fraid wire shorting out.
Diesel Rod
Old 05-16-2005, 11:15 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
is it fuse # 8 in under the dash? a 15 amp fuse? do you have remote keyless entry? if you do and it is #8 blowing un plug the remote keyless entry module under the dash. it is to the right of the column and has 3 connectors. i have this problem not with #8 blowing taking our speedo, door locks, courtesy lights and power mirrors. i unplugged this module and problem went away. replace the module and problem was gone for a month then came back and here i sit trying to figure it out.
hopw it helps
tim
Abner
07-25-2016 09:36 PM
Bob 79 supercab
05-29-2009 10:36 AM
ACarbone624
17
08-03-2007 10:09 PM
alteran
05-16-2007 06:20 PM
lynngl
04-18-2007 11:01 PM
Quick Reply: 1995 PSD no speedo, no cruise blowing fuse
