JB Weld Success?
Old May 15, 2005 | 11:04 PM
outrunm's Avatar
outrunm
I used it to repair a pool filter, and it worked great. I would never use it in an automotive engine application.
Old May 16, 2005 | 03:51 PM
rebocardo's Avatar
rebocardo
I hate it to say I did it, but, I used it inside an engine.
My oil pump shaft came out with the dist. on my 390. I used JB Weld to hold the shaft to the dist. so it would not drop into the oil pan. I had just finished resealing my 80 pound manifold and I did not want to pull the pan (been there and done that) at 10 p.m..
I waited until the JB Weld Quik was just about solid, but, still moved a little and inserted the dist into the hole so the alignment would be correct once set. I let it cure overnight along with the RTV for the manifold. So far, no problems, but, I do not push the engine to 6k either. Not recommended for the faint of heart.
Old May 17, 2005 | 02:37 AM
Greywolf's Avatar
Greywolf
It sounds like the shaft retainer clip was not installed when the oil pump was put in. This is done with the pan off the engine, and for a reason.
Go find the last person to put an oil pump in that machine and SLAP THEM!!!
"Ignorance tends to engender it's own reward. Hopefully painful..."
Old May 17, 2005 | 12:39 PM
Ford_Six's Avatar
Ford_Six
JB Weld is ok, but it's still a mechanical bond that is only as strong as the surface area it is stuck on and the tooth of the surface, and it will never be as strong as a molecular bond of a real weld.
Old May 17, 2005 | 08:54 PM
rebocardo's Avatar
rebocardo
I would like to slap them silly, but, it probably still would not wake them up. This truck came home on a flat bed for good reason. The guy told me it was a "hunting truck", which meant to me a junker. The heater was not working because 22 LRs where blocking the vents and hinge on the doors when the fell off the dash.
The first time I pulled the pan I actually pulled a complete tree leaf from the pan along with red RTV. I found beer bottles and cans inside the door panels when fixing the regulators.
The only way I could fix the electrics and lamps was by cutting everything out with a pair of snips.
If the motor did did not have 68 psi on two pistons I might have dropped the pan ... but I figured JB Weld could not hurt things much
Old May 18, 2005 | 04:50 AM
trike1946's Avatar
trike1946
I used it inside a motorcycle carburetor. One of the studs that held the float was broken off so I put it back together with the JB Quick version. Has held for the last 9 years.
Old May 18, 2005 | 08:32 PM
ckal704's Avatar
ckal704
It did not work to repair my cracked plastic coffee cup. The heat of expansion re-opened the crack after a few uses. I had considered using something like the paper clip idea to strenghten it, but the this was the cup I could put in the microwave to reheat the coffe and we all know what happens when you put metal in the microwave.
On the other hand, it worked great to repair a cracked electronic ignition coil for an Echo string trimmer. I was having great difficulty locating a replacement and the cost was going to be about 80 bucks anyway. The spark was jumping from the secondary windings to a fin on the cylinder. A dab of JB sealed it and it has not shorted out since!
Old May 18, 2005 | 08:58 PM
maticuno's Avatar
maticuno
If it is a metal to metal bond...I will ALWAYS use a real welder. If it is not metal to metal and/or I can't make a drywall screw work first...out comes the JB Weld.
Old May 18, 2005 | 10:26 PM
jimlj's Avatar
jimlj
It is not as good as Paul Harvey makes it out to be, but in my experiance works good when the surfaces are clean, and not great amount of stress or pressure is involved. I have patched several holes in gas tanks. I patched a hole in a lawn mower crank case that held for as long as I had the mower. I have used it several times where it failed, and over the years I have learned where it will and won't work (most of the time). I use a piece of window screen to add strength to repairs on broken hard plastic with some success.
I believe like maticuno, drywall screws are great for fixing most anything.
freirefishing
25
Jul 30, 2008 12:58 PM
woogs
May 16, 2006 04:10 AM
Beast12
Jun 3, 2005 11:26 PM
jskufan
Jul 23, 2004 02:44 AM
red_ranger 9
Feb 12, 2002 07:19 AM
