Removing the headlight switch itself...
Old May 13, 2005 | 03:52 PM
360and444's Avatar
360and444
I've read the FAQ and know how to remove the ****, but how do you get the switch itself out from behind the dash? I'm trying to replace mine and from the looks of the new one it should simply twist out, but I can't seem to get it. Hopefully it doesn't require removing the dash. If it does, is there a write up of the procedure for dash removal?
Thanks in advance for any help.
Travis
**the truck specs are in my sig. 73 F-100 4X4 360
Old May 13, 2005 | 04:10 PM
FordPickup460's Avatar
FordPickup460
There should be a little nut on the front of the switch, outside of the dash. I used vise grips to get mine off. Disconnect the battery before attepting anything.
Comanche1Star
Mar 11, 2014 08:28 AM
Jamie Arceneaux
Dec 27, 2012 07:46 AM
Monana ford Man
Jan 9, 2012 07:33 PM
1joshie1
13
Aug 23, 2010 09:41 PM
