DVD wiring
Old May 13, 2005 | 01:37 PM
atuck23's Avatar
atuck23
DVD wiring
I put this in the audio thread, and haven't heard anything back, just figured I would try here.
I just installed the new Clarion VRX755VD unit in my ,04 F-150. When I go to play a DVD it comes up as Audio Only. Guys at Crutchfield said I have to run a wire to my parking brake in order to play DVDs. They also said I must have the parking brake engaged in order play a DVD.
This seems odd for two reasons. One, this defeats the purpose of the DVD Player and for that matter I know several guys that have In-dash players that watch movies as they drive. Two, the fisrt thing the unit says when it comes on is that it is illegeal for the "driver" to watch the screen while driving. What about the passenger?
Any help would be greatly appreciate. Especially a way around this.
Old May 13, 2005 | 01:43 PM
MJEmerson's Avatar
MJEmerson
sounds stupid...i wonder if you could run that wire to something else and trick the system into thinking its the parking brake.
Old May 13, 2005 | 01:51 PM
atuck23's Avatar
atuck23
That's exactly what I thought. Why can't I simply treat it as a power wire and run it to the constantor something of that nature. The dealer won't provide any tips. I guess just to cover there butt. I'm gonna try something tonight.
Old May 13, 2005 | 02:38 PM
Johnnyboy04's Avatar
Johnnyboy04
I know that some systems simply require that wire be grounded for the system to work. Im not sure about your specific system though.
Old May 13, 2005 | 02:42 PM
atuck23's Avatar
atuck23
I have a ground wire, and the system has been grounded. The only thing left is a long green chord that supposively has to go to the parking brake.
Old May 13, 2005 | 03:16 PM
MJEmerson's Avatar
MJEmerson
you could probably test the parking break and find out what changing of the parking brake position does to the wire your supposed to tap into...if all it does is make it hot with 12v...you could probably just tap in somewhere else...might not be a bad idea to put an in line fuse though.
Old May 13, 2005 | 03:22 PM
atuck23's Avatar
atuck23
Thanks for the info, I'm about to go give it a shot now.
Old May 13, 2005 | 05:37 PM
ELO168's Avatar
ELO168
is ilegal to drive and wathc tv in the front
the passanger can watch only if the monitor is on that side
i had a switch connected to the wire
if the cops sees it, just flip the switch
see no screen when in d
or you can just ground the sucker
thanks
Old May 13, 2005 | 09:38 PM
atuck23's Avatar
atuck23
Elo,
I grounded the wire this afternoon and have the thing working. It is sweet. I am interested in this switch though. Could you tell me a little more about it.
Old May 16, 2005 | 02:32 PM
ELO168's Avatar
ELO168
good to hear it worked
just go to any radio shop and get a toggle switch
with on and off
wire it up
thats it
do hide the switch just in case
Old May 17, 2005 | 10:29 AM
MJEmerson's Avatar
MJEmerson
bunch of outlaws around here...i love it
Old May 17, 2005 | 10:39 AM
atuck23's Avatar
atuck23
Elo,
Thanks for the info on the switch. I think I might look into that one.
chavelka
2004 - 2008 F150
17
Dec 25, 2016 11:24 AM
85MD
2004 - 2008 F150
Oct 8, 2010 03:10 PM
351VENOM/LOUISIANA
Apr 12, 2006 12:57 AM
blown105
Aug 30, 2005 09:31 AM
