302 from 351?
Old May 12, 2005 | 06:56 PM
jwcorder's Avatar
jwcorder
302 from 351?
Is there an easy way to tell a difference?
Old May 12, 2005 | 07:59 PM
Red69's Avatar
Red69
Extra bolts on the intake on a 351.
Old May 12, 2005 | 10:41 PM
jwcorder's Avatar
jwcorder
how many we talking here? I am trying to determine engine size in my 70.
Old May 13, 2005 | 05:31 AM
jowilker's Avatar
jowilker
Unless it is a refit, it is a 302. It was after 80 when the first 351W was installed from the factory.
John
Old May 13, 2005 | 07:14 AM
Red69's Avatar
Red69
I was always told that a 351 had 2 more bolts in the intake. I have a 351w in a Mustang and it has 12 bolts in the intake. The 302 in my truck has 12 also. So I guess that wasn't true about the difference. I guess you need to look up casting #'s.
Old May 13, 2005 | 12:37 PM
JasonBrod's Avatar
JasonBrod
The EGR vlave bolts directly to the manifold on a 351W. On a 302 the EGR connects to the carb spacer. The other way you can tell is that the manifold is quite larger then the 302.
Most everything else though is the same. I do believe the block is the same but the heads are not.
Old May 14, 2005 | 11:53 AM
spitfyre's Avatar
spitfyre
the 302 has a 1-5-4-2-6-3-7-8 firing order and the 351 has 1-3-7-2-6-5-4-8 but if your engines been rebuilt it might be a 351w with a 302 cam, in which case it would have the 302 firing order.
Old May 15, 2005 | 12:52 AM
wyatts72's Avatar
wyatts72
the intake is wider and taller and the valve cover bolt holes are different. 1972 f150 351w.
