Carb settings
Old May 13, 2005 | 10:43 AM
JasonBrod's Avatar
JasonBrod
Carb settings
OK. I think I have a carb problem that I need help with.
I have a 70 with a 2 barrel Motorcraft carb, with an electrical choke. When I am at full throttle the motor kind of stutters, especially when the motor is is barely warm. If the chock was out of adjustment, would it cause this as well as hard starting?
Are there any better alternatives to the Motorcraft carbs?
Old May 14, 2005 | 12:01 PM
dcotton's Avatar
dcotton
About 3 months ago I rebuilt my motorcraft 2 barrell. The kit was less than 20 bucks and it has pics with instruction on how to set everything up.
D
Old May 15, 2005 | 09:43 AM
achtungeveryone's Avatar
achtungeveryone
Jasonbrod: your carb is pretty good if you get it set up. I haven't touched mine nor did the previous owner who had the truck for about 5 years.
ONE note: they say most carb problems are really ignition problems so make sure everything is firing like it should.
Achtung
jmikeyj4
Oct 22, 2010 01:02 AM
71FoMoCo
May 4, 2009 09:08 AM
dialogueonlife1
May 9, 2007 03:56 AM
dean307
Nov 24, 2006 11:36 PM
8ITCOOL
Mar 16, 2004 07:07 PM
